Latchmor 584 Posted October 23, 2017 Posted October 23, 2017 Hi, I've got the same issue (seeing the deflate message) but having trouble updating from .18 to .19. Will try again shortly and post logs if still the same. Thanks
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 I am just running a guide refresh with .19 to see if I see any change. Krs Mark
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 Hi, I've got the same issue (seeing the deflate message) but having trouble updating from .18 to .19. Will try again shortly and post logs if still the same. Thanks What OS? Krs Mark
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 (edited) Ok, Just ran it and my guide is fine and no deflate errors in log. Perhaps this is lineup related. Can one of you try using MY lineup? Postcode: LE10 Lineup: Youview - Central Midlands Krs Mark Edited October 23, 2017 by maegibbons
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 Also I have my guide set to 14 days in settings. Krs Mark
Latchmor 584 Posted October 23, 2017 Posted October 23, 2017 (edited) Hi, same with Version 3.2.33.19 beta. Windows 7 x64 2 x HDHR4-2DT Cheers Edit: My SD lineup is fine as I use this with EPG123 for WMC and it has updated fine. Edited October 23, 2017 by Latchmor
Nathanio 35 Posted October 23, 2017 Author Posted October 23, 2017 Ok, Just ran it and my guide is fine and no deflate errors in log. Perhaps this is lineup related. Can one of you try using MY lineup? Postcode: LE10 Lineup: Youview - Central Midlands Krs Mark No difference for me with your postcode. Not sure if it is relevant but my cache folder is not in the default location. I've moved all the metadata and cache files to a separate SSD for speed
Latchmor 584 Posted October 23, 2017 Posted October 23, 2017 Just edited post #31 to say my SD lineup is fine as I use this with EPG123 for WMC and it has updated fine. Cheers
Nathanio 35 Posted October 23, 2017 Author Posted October 23, 2017 I've just installed emby beta to my laptop and it has downloaded the guide without issue. But that was a completely fresh install and with the temp folder in the default location. What should I check next?
Nathanio 35 Posted October 23, 2017 Author Posted October 23, 2017 what versions of windows? Current Server is Windows Home Server 2011 and laptop is Windows 10.
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 WHS 2011 and has been running solid for weeks happily. @@Luke from page 1
Nathanio 35 Posted October 23, 2017 Author Posted October 23, 2017 Just tried rebooting my server and updated to .20 but same difference. I appreciate the support. Could something of got corrupted in the change over from old to new .net core?
maegibbons 1287 Posted October 23, 2017 Posted October 23, 2017 Did you move from mono install to .net core when this happened? My personal feeling is that it is an issue with the OS httpclient library. Your 2011 install is quite old and so was @@Latchmor Win 7 install. The .net core version could be driving the underlying OS httpclient in a slightly different way. i am not sure whether even this is technically correct. i.e. does .net core have its own FULL implemantation of the httpclient anyways and is not reliant in any way on OS librarys??? However, this is just gut feeling. I dont have a Win7 or 2011 VM that i could test it on at present. If i find a way to easily test it i will. Krs Mark
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Did you move from mono install to .net core when this happened? My personal feeling is that it is an issue with the OS httpclient library. Your 2011 install is quite old and so was @@Latchmor Win 7 install. The .net core version could be driving the underlying OS httpclient in a slightly different way. i am not sure whether even this is technically correct. i.e. does .net core have its own FULL implemantation of the httpclient anyways and is not reliant in any way on OS librarys??? However, this is just gut feeling. I dont have a Win7 or 2011 VM that i could test it on at present. If i find a way to easily test it i will. Krs Mark Yea that's similar to what I'm starting to wonder about.
Nathanio 35 Posted October 24, 2017 Author Posted October 24, 2017 Yea that's similar to what I'm starting to wonder about. You both could be onto something. I've just tested in a Win7 VM and got the deflate error on that too. Is there any chance this can be fixed or will I have to update my OS? It is running fine apart from this issue and sorta reluctant to change if I can
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 (edited) I can't change from Windows 7 but I can do a fresh install of Emby .net core if needed. I was planning to, just not yet! Actually, what stage is the migration from old .net to new .net core? I'm always on beta so have I been migrated already or do I have to manually make the change? Cheers Edited October 24, 2017 by Latchmor
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Yea try grabbing the portable install from the website as a test.
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Yea try grabbing the portable install from the website as a test. Will do tonight. Thanks
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Yea try grabbing the portable install from the website as a test. Hi Luke, setup portable as requested. It's not working but a different outcome. Refresh guide hardly does anything and only lasts 3 seconds so not much in the log attached. Everything in the Live TV section setup the same as my normal install. Removed the SD provider and added again a few times but always the same. Cheers
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Also a small alignment issue on the provider page.
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Hi Luke, setup portable as requested. It's not working but a different outcome. Refresh guide hardly does anything and only lasts 3 seconds so not much in the log attached. Everything in the Live TV section setup the same as my normal install. Removed the SD provider and added again a few times but always the same. Cheers Your tuner is returning 0 channels.
Latchmor 584 Posted October 24, 2017 Posted October 24, 2017 Your tuner is returning 0 channels. Sorry had a brain fart. Just realised I got mixed up between favourites in Emby and favourites set in the HDHomerun Refreshing now, log to follow if it fails...
Luke 42237 Posted October 24, 2017 Posted October 24, 2017 Back to original errors with DEFLATE... Can you setup this portable version and compare: https://github.com/MediaBrowser/Emby/releases/download/3.2.33.0/embyserver-win-x64-3.2.33.0.7z Thanks.
