AFFASocial 6 Posted October 18, 2017 Posted October 18, 2017 (edited) First I want top say Hello to everyone as I have not been active since 4/2017. I try and post help for a better experience on old machines as well as NEW ONES alike. OK i'm sure we all have had times when things lag and or are a bit jumpy. Fear not i'm gonna show you hows to use as little as 700mb on a system that is a i3 with dual processor and 4 cores and 6gigs of memory. This will help keep the memory free on all systems even new ones like the system I have now a i7 6th generation Dual processor and 8 cores with 16giggs of memory. READY OK here we go. All you need to do is download a application called Windows Doctor this is the main Screen PICTURE BELOW Now Select Advanced Tools Tab SEE BELOW PICTURE Now Select Memory Defrag Tab SEE BELOW PICTURE you might have to click it 2 times Now select the Settings Tab and set the options exactly like you see in this pic below Click on OK and watch the memory start going down it will free all memory as soon as it used and dumped you will not even notice. When you exit the MEMORY Defrag it will be in the TRAY with running apps Now you can tell it to start with windows but for me does not work just run the app as I showed you how to start the Memory DEFRAG you only have to start it when windows loads you do no have to set the settings after the first run it will work and you will see no HUGE jump in memory or in the CORES consumption. This has work on every system I have tried or owned WELL! There ya go Peace from PCMAN/AFFA Edited October 18, 2017 by cnjnorton
