Luke 42246 Posted November 14, 2017 Posted November 14, 2017 After five minutes we abort the extraction, that is why. Nobody is going to sit and wait five minutes for their video to load so at some point we need to kill the background process.
fbrassin 47 Posted November 15, 2017 Author Posted November 15, 2017 OK. As i see the .srt file is filling at about reproduction speed, isn't it possible to start play even if the srt file is not completed. It will complete while playing. Or is it not possible?
Luke 42246 Posted November 15, 2017 Posted November 15, 2017 OK. As i see the .srt file is filling at about reproduction speed, isn't it possible to start play even if the srt file is not completed. It will complete while playing. Or is it not possible? Right, see post #43.
fbrassin 47 Posted November 15, 2017 Author Posted November 15, 2017 Right, see post #43. Ahh, ok. So, my other question is. Is tehre a way to manually extract subtitles from movie? I mean a command that i can manually run via terminal?
Luke 42246 Posted November 15, 2017 Posted November 15, 2017 yes there's a couple simple examples here: https://trac.ffmpeg.org/wiki/ExtractSubtitles 1
fbrassin 47 Posted November 16, 2017 Author Posted November 16, 2017 That's interesting. I'll give a look and see if i can bypass my problem
fbrassin 47 Posted November 16, 2017 Author Posted November 16, 2017 I found this line to extract forced subtitles. /var/lib/emby-server/ffmpeg/20170308/ffmpeg -forced_subs_only 1 -i input.mkv output.srt It is working now. Let's see tonight if it is ok. It is extracting veryyyyyyyyyyy sloooooollllyyy size= 2kB time=00:01:48.35 bitrate= 0.1kbits/s speed=1.68x
fbrassin 47 Posted November 16, 2017 Author Posted November 16, 2017 Mhh, it took about half an hour to extract subtitles of an episode during 50 minutes. I'm afraid it is not a possibility to do this. @@Luke you told in post #49 that maybe plex was downloading subtitles on the fly, but what do you mean? I select incorporated subtitles when play a movie with plex. I think they are showing incorporated subtitles in the movie. One thing is clear to me. Is it necessary to extract subtitles? Why subtitles cannot be shown directly during transcoding or streaming as they are incorporated in the movie?
fbrassin 47 Posted November 20, 2017 Author Posted November 20, 2017 Any answer for my previuos post?
casperghst42 5 Posted November 23, 2017 Posted November 23, 2017 Player: AppleTV I have a similar problem, I have some media where the subtitles are being extracted eventhough I select them to be played without subtitles, and as the subtitle isn't supported it does not do a copy, but a full extraction which puts my CPU into 100% utilization. I have hw encoding enabled, and it works, except for subtitles ... -- snip -- Transcoding The media is being converted into a format that is compatible with the device that is playing the media. Reason for transcoding: Subtitle format not supported -- snip -- Media information: General Unique ID : 234914162165839089565732804743883302969 (0xB0BAD269D8980E769DD558EFB536A839) Complete name : media-file-name.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 2.06 GiB Duration : 52 min 56 s Overall bit rate : 5 572 kb/s Movie name : media-file-name Encoded date : UTC 2016-11-07 09:01:09 Writing application : mkvmerge v9.4.0 ('Knurl') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Cover : Yes Attachments : cover_land.jpg / small_cover.jpg / small_cover_land.jpg / cover.jpg Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 52 min 56 s Bit rate : 5 077 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.102 Stream size : 1.88 GiB (91%) Title : media-file-name Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 52 min 56 s Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 spf) Bit depth : 16 bits Compression mode : Lossy Stream size : 145 MiB (7%) Title : media-file-name Language : English Default : Yes Forced : No Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Default : Yes Forced : No Is there a way to: 1) disable the extraction (permanently) ? 2) get a version of ffmpeg which can handle these subtitles? Cheers, Casper ffmpeg-remux-724d3967-c9f4-46c2-9ec0-f81e630ed783.txt
fbrassin 47 Posted November 24, 2017 Author Posted November 24, 2017 Let's hope these problems with subtitles can be solved. This is the only thing that stops me from leaving plex and use emby.
NeonGOD 3 Posted August 5, 2018 Posted August 5, 2018 I know this is an old Thread.. But i stopped using Emby because of this exact behaviour and switched to plex which have no problem with ingrated subs on a rclone mount... now im facing a new server setup and was wondering if this behaviour still is a problem?? 'cause i rather be running emby than plex.. but won't test it out if still doesn't work so fbrassin did u find a solution on this problem ??
Luke 42246 Posted August 5, 2018 Posted August 5, 2018 Hi there, have you described your issue in detail? Best thing to do is see how to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
fbrassin 47 Posted August 6, 2018 Author Posted August 6, 2018 I know this is an old Thread.. But i stopped using Emby because of this exact behaviour and switched to plex which have no problem with ingrated subs on a rclone mount... now im facing a new server setup and was wondering if this behaviour still is a problem?? 'cause i rather be running emby than plex.. but won't test it out if still doesn't work so fbrassin did u find a solution on this problem ?? Not at the moment. I'm waiting to see with new player if it will change.
NeonGOD 3 Posted August 6, 2018 Posted August 6, 2018 Not at the moment. I'm waiting to see with new player if it will change. Okay i will wait then Thanks for reporting back
NeonGOD 3 Posted November 11, 2018 Posted November 11, 2018 I recently changed my rclone setup to try out the VFS instead of cache backend.. and just for kicks i tried installing emby again just to test if it made any differnce and it did.. don't know if the emby team have fixed subtitles or if it's because of the shift to VFS.. i basicly did a setup based on this: https://github.com/animosity22/homescripts
fbrassin 47 Posted November 12, 2018 Author Posted November 12, 2018 Are you using gdrive? In case did you have bans using VFS?
NeonGOD 3 Posted November 18, 2018 Posted November 18, 2018 Yes im using gdrive and got no bans whatsoever.. it runs smoothly.. i basically just setup like the scripts from animosity i linked earlier..
Luke 42246 Posted December 21, 2018 Posted December 21, 2018 You might like this: https://emby.media/community/index.php?/topic/66876-36080-improved-subtitle-delivery Thanks. 1
