BestYohman 5 Posted October 15, 2017 Posted October 15, 2017 I have been having issues over the last 2 weeks where any apps (theater, android) will show connection failure but I am able to access through chrome at home or away. Restart of the emby server fixes the issue but it takes over a min for the reboot button to show up in chrome. I have tried removing plugins to see if one is causing a issue. Sent from my SM-G955U using Tapatalk
BestYohman 5 Posted October 15, 2017 Author Posted October 15, 2017 I have been having issues over the last 2 weeks where any apps (theater, android) will show connection failure but I am able to access through chrome at home or away. Restart of the emby server fixes the issue but it takes over a min for the reboot button to show up in chrome. I have tried removing plugins to see if one is causing a issue. Sent from my SM-G955U using Tapatalk Running public 3.2.33.0 Sent from my SM-G955U using Tapatalk
BestYohman 5 Posted October 15, 2017 Author Posted October 15, 2017 Sorry forgot to post it.Log.txt Sent from my SM-G955U using Tapatalk
BestYohman 5 Posted October 15, 2017 Author Posted October 15, 2017 No Sent from my SM-G955U using Tapatalk
BestYohman 5 Posted October 15, 2017 Author Posted October 15, 2017 It's when I'm trying to access from theater or from Android app. Sent from my SM-G955U using Tapatalk
Luke 42203 Posted October 15, 2017 Posted October 15, 2017 Try entering the connection address manually, just in case the app might have out of date connection info. thanks.
BestYohman 5 Posted October 15, 2017 Author Posted October 15, 2017 I have tried to enter the local address. Seems to time out. When accessing it through chrome it loads slow. I have noticed that my CPU sits at 15-25 percent used by emby when nothing is going on. Ram usage sits at 250mb. When accessing through chrome it seems to load extreamy slow. After I restart emby everything is fast again. I have no live TV. The only plugins I have left now is theme video, trailers, backup and restore. Sent from my SM-G955U using Tapatalk
Luke 42203 Posted October 15, 2017 Posted October 15, 2017 It sounds like a network problem then to be honest.
BestYohman 5 Posted October 16, 2017 Author Posted October 16, 2017 I thought that also at first. I have changed out the router and checked network logs. Everything stops at emby. The only items affected is emby apps. Is there anyway of changing connection timeouts? Sent from my SM-G955U using Tapatalk
