nucahx 0 Posted October 12, 2017 Posted October 12, 2017 I am having a strange playback issue with some old episodes of Babylon 5. The audio is fine, but the video seems slowed down for some reason and it stays out of sync. I have included the server and transcode logs and really appreciate the support. I tried many other videos and they all seemed to play fine. Also the same video runs without issue in Plex. Thanks server.txt transcode.txt
Luke 42243 Posted October 12, 2017 Posted October 12, 2017 Hi, try shutting down the server and deleting this folder: C:\Users\marlin\AppData\Roaming\MediaBrowser-Server\ffmpeg\20151111 Then start back up. See if that helps. Thanks !
Happy2Play 9812 Posted October 12, 2017 Posted October 12, 2017 (edited) Shows how old your install is, still in MediaBrowser-Server folder. But at least you are on the current server. Edited October 12, 2017 by Happy2Play
nucahx 0 Posted October 12, 2017 Author Posted October 12, 2017 Thanks for the suggestion but I still get the same playback issue. It didn't change anything. I attached the latest logs as well transcode.txt server.txt
