Angelblue05 4132 Posted November 12, 2017 Posted November 12, 2017 (edited) @@tr0nllam Ok, try this build, let me know if it resolves it. I really hope it does. plugin.video.emby-2.3.57a.zip Edited November 12, 2017 by Angelblue05
tr0nllam 36 Posted November 12, 2017 Author Posted November 12, 2017 (edited) @@Angelblue05 It took awhile to get it to fail. Here's the log with multiple successful views until a failure at the end. kodi.log Edited November 12, 2017 by tr0nllam 1
Angelblue05 4132 Posted November 12, 2017 Posted November 12, 2017 I am pretty sure this will be the one. plugin.video.emby-2.3.57a.zip 1
tr0nllam 36 Posted November 12, 2017 Author Posted November 12, 2017 (edited) @@Angelblue05 So far, so good. I'll let you know if anything goes wrong. Thanks for all your help. Edited November 12, 2017 by tr0nllam 1
Luke 42251 Posted December 5, 2017 Posted December 5, 2017 Our Trakt plugin has been updated to 3.1.2. Due to Trakt API changes, you will need to install the update, and then re-authenticate using the trakt plugin configuration screen. In addition, there are improvements to the Trakt syncing process. Please let us know if this helps. Thanks !
