Catsrules 17 Posted October 11, 2017 Posted October 11, 2017 I have notice that when I play an audio book or podcast from a resumed location, if I pause the playback then resume playback it starts back on the last resumed location.For example if I resume a podcast at 00:54:34 listen for 5 minutes and pause it so it is now at 00:59:34. When I press play again it will go back to the 00:54:34 instead of 00:59:34. To get around this I need to stop the podcast instead of pause, this way it will update the resume location and go to the correct time. This issue does not happen if there is no resumed location. When starting an audio book/podcast from the beginning play/pause works as intended.Hopefully this explanation was somewhat intelligible. Let me know if I need to explain any thing.
Luke 42243 Posted October 12, 2017 Posted October 12, 2017 hi @@Catsrules, this is resolved for the next release of the app, thanks ! 1
Catsrules 17 Posted October 12, 2017 Author Posted October 12, 2017 hi @@Catsrules, this is resolved for the next release of the app, thanks ! Thanks, I will look forward to it
