horstepipe 423 Posted October 26, 2017 Posted October 26, 2017 (edited) I was too curious whether my problems would persist when changing to the pro plan, so I bought it and everything works fine with it (whithout using any page rules at all). If there‘s a way to fix it without paying the 20 bucks/month I‘d really prefer coming back to free plan, but now it looks really like the free plan is limiting here. Maybe you‘re an „older“ customer so there are some limitations active for me but not for you? Edited October 26, 2017 by horstepipe
Jdiesel 1437 Posted October 26, 2017 Posted October 26, 2017 I was too curious whether my problems would persist when changing to the pro plan, so I bought it and everything works fine with it (whithout using any page rules at all). If there‘s a way to fix it without paying the 20 bucks/month I‘d really prefer coming back to free plan, but now it looks really like the free plan is limiting here. Maybe you‘re an „older“ customer so there are some limitations active for me but not for you? I'm also on the free plan and don't experience any apparent web socket issues even with no page rules. I didn't read the entire thread but what is the issue exactly? Just the web sockets timing out?
horstepipe 423 Posted October 26, 2017 Posted October 26, 2017 Mhh ok now I‘m getting Too many open files again. How could this message come from?
horstepipe 423 Posted October 26, 2017 Posted October 26, 2017 I'm also on the free plan and don't experience any apparent web socket issues even with no page rules. I didn't read the entire thread but what is the issue exactly? Just the web sockets timing out? At the moment two problems: - The websockets (but this seemed to work with pro plan) - The ‚too many open files‘ error
pir8radio 1313 Posted October 26, 2017 Posted October 26, 2017 I was too curious whether my problems would persist when changing to the pro plan, so I bought it and everything works fine with it (whithout using any page rules at all). If there‘s a way to fix it without paying the 20 bucks/month I‘d really prefer coming back to free plan, but now it looks really like the free plan is limiting here. Maybe you‘re an „older“ customer so there are some limitations active for me but not for you? cloudflare only limits concurrent websocket connections.. and its a really high number there is no way you are reaching it. Mhh ok now I‘m getting Too many open files again. How could this message come from? show us a screen shot of what you are talking about.
horstepipe 423 Posted October 26, 2017 Posted October 26, 2017 show us a screen shot of what you are talking about. I can’t immediately because it is working at the moment. When I try to open the Emby Server Webgui I‘m getting a blank white page, only written Too many open files in plain text in the top left corner
horstepipe 423 Posted October 27, 2017 Posted October 27, 2017 (edited) Ok guys sorry again, the error comes from Emby not from cf. I thought it was coming from cf because as I tried to reach Emby via its origin IP it was working, but this was pure coincidence. The error seems to occur on library scan, so this is a topic for another thread (although I never saw it before). Sorry again for all the bullshit I‘m spreading here :-) So apart from that problem everything works fine for now. Let‘s take a look at the websockets when I‘m at the free plan again in 4 weeks. Thank you very much Edited October 27, 2017 by horstepipe
graphixmaker 2 Posted October 27, 2017 Author Posted October 27, 2017 Problem is solved, there was simply a second A-record which shouldn’t have been there, sorry for wasting your time on that. Now I‘m facing the same problem as the OP: The websockets don’t keep alive. I am not using nginx, only Cloudflare. So for the guys who do not have this problem, could we please clarify if you’re on Cloudflare‘s free or pro Plan? I could imagine that this is a limitation of the free plan. @@graphixmaker Have you already been able to solve the problem? I have not solved the problem I'm having. I've redone my nginx conf to the previous examples but the issue persists. Everything else works perfectly but the web sockets die just over a minute into the connection.
horstepipe 423 Posted October 27, 2017 Posted October 27, 2017 I have not solved the problem I'm having. I've redone my nginx conf to the previous examples but the issue persists. Everything else works perfectly but the web sockets die just over a minute into the connection. That confirms my thesis that this is a limitation of the free plan, maybe for newer users only. Try the pro plan once to see if this resolves the problem for you, too.
horstepipe 423 Posted November 9, 2017 Posted November 9, 2017 Hey It caught my eye that Emby dashboard sometimes shows me users from a Cloudflare IP, sometimes from their own. How does this happen? I thought through the reverse proxying of Cloudflare I‘d only see Cloudflare IPs from all users?
pir8radio 1313 Posted November 11, 2017 Posted November 11, 2017 Hey It caught my eye that Emby dashboard sometimes shows me users from a Cloudflare IP, sometimes from their own. How does this happen? I thought through the reverse proxying of Cloudflare I‘d only see Cloudflare IPs from all users? If you are using nginx and its setup correctly, you should always see two IP's like 0.0.0.0, 1.1.1.1 the first one being your users IP and the second cloudflare. That is the X-Forwarded-For header doing its job. Each time a user passes through a reverse proxy, the proxy adds its ip to that list... 1
horstepipe 423 Posted November 11, 2017 Posted November 11, 2017 If you are using nginx and its setup correctly, you should always see two IP's like 0.0.0.0, 1.1.1.1 the first one being your users IP and the second cloudflare. That is the X-Forwarded-For header doing its job. Each time a user passes through a reverse proxy, the proxy adds its ip to that list... Thanks, but I don’t use nginx or any other additional reverse proxy. It looks like when a user signes on, Emby registeres a Cloudflare IP, and when a user signes off, Emby registeres his origin IP. I hoped to be able to add a layer of privacy for my users with cf by obfuscating their IPs in my logs, but ok, no big deal.
pir8radio 1313 Posted November 11, 2017 Posted November 11, 2017 Thanks, but I don’t use nginx or any other additional reverse proxy. It looks like when a user signes on, Emby registeres a Cloudflare IP, and when a user signes off, Emby registeres his origin IP. I hoped to be able to add a layer of privacy for my users with cf by obfuscating their IPs in my logs, but ok, no big deal. I would expect you to always see two IP's the user, cloudflare. You are not bypassing cloudflare for anything are you? Like they hit the server with http first then are redirected to https on another ip or something? But yes, it looks to be working as it normally does.
jscoys 147 Posted December 20, 2017 Posted December 20, 2017 Hello guys I’m a noob! Could someone explain me how to use cloud fare and setup everything like I would be 6 years old please? I bought a domain name on cheap, then I redirected to use cloud fare but now what I’m supposed to do on cloud fare side? Do I need a static IP? Sent from my iPhone using Tapatalk
pir8radio 1313 Posted December 21, 2017 Posted December 21, 2017 Hello guys I’m a noob! Could someone explain me how to use cloud fare and setup everything like I would be 6 years old please? I bought a domain name on cheap, then I redirected to use cloud fare but now what I’m supposed to do on cloud fare side? Do I need a static IP? Sent from my iPhone using Tapatalk no you do not need a static IP see https://support.cloudflare.com/hc/en-us/articles/200168816-Does-Cloudflare-work-with-Dynamic-DNS-Can-I-update-my-DNS-records-remotely- 1
jscoys 147 Posted December 21, 2017 Posted December 21, 2017 Ok what I'm support to put in my CloudFare config? It tried to put my external IP Address and when I go to on the domain name it doesn't give me anything... How do you manage the 8096? Do I have to change it for 8080? My ISP is blocking the 80...
dcrdev 255 Posted December 21, 2017 Posted December 21, 2017 Ok what I'm support to put in my CloudFare config? It tried to put my external IP Address and when I go to on the domain name it doesn't give me anything... How do you manage the 8096? Do I have to change it for 8080? My ISP is blocking the 80... 8096 isn't supported by CloudFlare, these are: For requests made via HTTP: 80 8080 8880 2052 2082 2086 2095 For requests made via HTTPS: 443 2053 2083 2087 2096 8443 Be advised that CloudFlare doesn't support port redirection, so if your not using 80/443 - you'll always need to specify the port when connecting i.e. http://domain.com:8080, https://domain.com:8443. Equally the universal SSL feature in CloudFlare needs the origin server to also support SS, it won't upgrade http tp https.
pir8radio 1313 Posted December 22, 2017 Posted December 22, 2017 Ok what I'm support to put in my CloudFare config? It tried to put my external IP Address and when I go to on the domain name it doesn't give me anything... How do you manage the 8096? Do I have to change it for 8080? My ISP is blocking the 80... Yes @@dcrdev is correct, you have to either setup your emby server to use standard HTTP/HTTPS ports (80/443) or use one of their supported ports he listed above. So you bought a domain, you changed your domain DNS servers to use the cloudflare DNS servers right? You then create an A record in cloudflare that is your base domain name that points to your server IP address. You should then update your emby server to use port 80 and 443 ideally, and update the emby "External Domain" to show your domain name. If you don't want to change your emby local ports, you can port forward from 80/443 in your router to your existing local emby ports. Once you get that far let us know. THere are a few cloudflare settings you should add that are emby specific, but those additional settings only improve the efficiency when using cloudflare.
jscoys 147 Posted December 22, 2017 Posted December 22, 2017 Hello thx for your advices! It worked on yesterday, I opened the port 8080 redirecting to 8096 internally, had a A entry on Cloudflare "domain.com" pointing to my IP Adress, and a CNAME "WWW" pointing to my "domain.com" and today nothing's working. Cloudflare after a while is sending that my "domain.com" seems broken... On the domain name I just checked and the two Nameservers DNS from CloudFlare are there... I don't know! Do I have have to add more entries in CloudFlare than just an A and a CNAME?
dcrdev 255 Posted December 22, 2017 Posted December 22, 2017 Hello thx for your advices! It worked on yesterday, I opened the port 8080 redirecting to 8096 internally, had a A entry on Cloudflare "domain.com" pointing to my IP Adress, and a CNAME "WWW" pointing to my "domain.com" and today nothing's working. Cloudflare after a while is sending that my "domain.com" seems broken... On the domain name I just checked and the two Nameservers DNS from CloudFlare are there... I don't know! Do I have have to add more entries in CloudFlare than just an A and a CNAME? You do not no - have you set up the dynamic dns I sent you the link to? Maybe your ip has changed...
jscoys 147 Posted December 22, 2017 Posted December 22, 2017 (edited) No I checked my IP is exactly the same... I tried to remove/change nameservers, remove/add again the A and CNAME. Will wait for 24/48 hours and see. Thx for your help! Oh and if I put my ip:8080 it works... Edited December 22, 2017 by jscoys
jscoys 147 Posted December 22, 2017 Posted December 22, 2017 And a ping on domain.com is working... weird thing...
jscoys 147 Posted December 22, 2017 Posted December 22, 2017 Ok it seems that I can’t go from internal network to domain.com, only from outside... do you why? Sent from my iPhone using Tapatalk
dcrdev 255 Posted December 22, 2017 Posted December 22, 2017 Ok it seems that I can’t go from internal network to domain.com, only from outside... do you why? Sent from my iPhone using Tapatalk Yep because you need nat loopback for that to work without your own dns server, some routers don't have this. On Linux I use dnsmasq internally - not sure what's out there for Windows.
jscoys 147 Posted December 24, 2017 Posted December 24, 2017 Hum it's fine... I don't have any interest to use mydomain from inside network, it will be faster anyway than going outside and then inside ;-) Thx guys for your help! 1
