christoph86 12 Posted March 1, 2014 Posted March 1, 2014 So my mkv files no longer play audio within MBC. They used to. They play fine in MBT on the same computer. Only have the LAV codecs installed. The link to the logfile from mbc listed below. Any help appreciated. Thanks. https://www.dropbox.com/s/16zx024v114i1se/MBC%20Log.txt
Solution ebr 16333 Posted March 1, 2014 Solution Posted March 1, 2014 Log file won't tell us anything unfortunately. It must be a codec issue. Perhaps a difference between 32 and 64bit codecs...? 1
christoph86 12 Posted March 2, 2014 Author Posted March 2, 2014 Got it figured out. Somehow I had DTS bitstreamimg checked and unchecking fixed it. Thanks!
