darkassassin07 672 Posted October 9, 2017 Posted October 9, 2017 Are there any plans to incorporate an 8 or 16 band eq mixer for audio streams? Possibly with the ability to save presets. I tend to switch up audio setups very frequently and like to tweak EQs to match.
darkassassin07 672 Posted October 10, 2017 Author Posted October 10, 2017 (edited) Ideally all of them to make it available for everyone, but the web app and the android primarily. Edited October 10, 2017 by darkassassin07
Jdiesel 1435 Posted October 10, 2017 Posted October 10, 2017 (edited) Just a heads up for Windows users. Equalizer APO will do everything you've ever wanted plus so much more. Paired with a $100 microphone and REW (free) you can exceed the room correction and eq management of $4000+ receivers. Or just use it for it great eq that works system wide. https://sourceforge.net/projects/equalizerapo/ Honestly I can't state enough how awesome this software is. Edited October 10, 2017 by Jdiesel
nankinodai 0 Posted March 10, 2018 Posted March 10, 2018 Just a heads up for Windows users. Equalizer APO will do everything you've ever wanted plus so much more. Paired with a $100 microphone and REW (free) you can exceed the room correction and eq management of $4000+ receivers. Or just use it for it great eq that works system wide. I see this software affecting my line out but not the EQ when casting. Is there something I'm missing?
Jdiesel 1435 Posted March 10, 2018 Posted March 10, 2018 I see this software affecting my line out but not the EQ when casting. Is there something I'm missing? You you mean when using a Chromecast? If so then yes there will be no EQ applied to it as it a completely different device and your computer is only passing a link to the file and not modify it.
