MrSmoke 11 Posted March 1, 2014 Posted March 1, 2014 (edited) Last.fm Scrobbler Description This plugin will scrobble your tracks to your Last.fm account as well as marking tracks as loved when you favourite them from within MediaBrowser. Also included is a Scheduled Task to import your play counts and loves from your Last.fm account. Configuration Before you can scrobble to Last.fm or use the import task you will need to configure the Last.fm account for the desired user. Required is your Last.fm username and password. PLEASE NOTE: The plugin will not store your password. There are currently two options available in the plugin: Enable Scrobbling for this user? Will, as the label state, enable scrobbling for the selected user Sync favourites for this user? Will enable tracks to be marked as loved in Last.fm when the track is favoured in MediaBrowser. This option also enables loved tracks to be marked as favourite when importing data via the Scheduled Task. Important - The import task will unfavourite any tracks not marked as loved in last.fm, so before using this option make sure all your local favourites are marked as loved Troubleshooting TBA Change Log/Release History 1.0.5174.2702 (1/Mar/2014) Initial Development Release. This build is currently considered an Alpha so please beware. Edited March 1, 2014 by MrSmoke 4
ebr 16332 Posted March 1, 2014 Posted March 1, 2014 Yeah - music folks who use last.fm - please give this a whirl and help Mr. Smoke iron out any issues.
Luke 42237 Posted July 1, 2018 Posted July 1, 2018 https://emby.media/community/index.php?/topic/60375-lastfm-plugin-is-back/
