echoxxzz 22 Posted October 7, 2017 Posted October 7, 2017 If I configure ET to use MadVR I can't resume any videos. I have to hit pause then play to get the video playing again. I can start playing a video just fine. I tested this on three different PC's and I get the same results using Emby Theater 2.9.2 and 2.8.8. Is there a setting I need to configure in order to get Emby-Theater to resume a video using MadVR?
Luke 42243 Posted October 7, 2017 Posted October 7, 2017 What happens if you use the default mpv-based video player?
echoxxzz 22 Posted October 7, 2017 Author Posted October 7, 2017 mpv works perfectly. I played a bit with the MadVR settings and if I enable "delay playback start until render queue is full" I can now resume. I was also having problems seeking and enabling "delay playback start after seeking" fixed that problem. Both of these settings are under "Rendering | General Settings" in MadVR.
Luke 42243 Posted February 13, 2018 Posted February 13, 2018 Just a heads up the next version of the app will be removing madvr again, but I think you'll find the external player experience will be much better. This will allow you to use MPC-HC with MadVR if you desire. You're welcome to try out a test version here: https://emby.media/community/index.php?/topic/46763-theater-mpv-test/page-1 Thanks !
