bb2402 0 Posted October 6, 2017 Posted October 6, 2017 Hello, i found no solution for my problem: I use emby on my server in a docker container with docker-compose. I can access from emby apps, KODI or chrome with no problems. But the UPNP Server not work. I think the problem is the IP adress. The container use the bridge mode. Ports 8096, 8920 and 1900 UDP are open. The Ip of my server is 192.168.178.191 but the bridge docker network is 172.18.0.0. When my client now show for a UPNP server he becomes this IP but this IP in my network not work. When i use host mode in docker works all well but for me is this not the solution. For emby himself my solution was using in Server config "Bind on local Network...". Now i can access my server with the correct IP Adress. But this not work for DLNA. What can i do??? Thank you
Luke 42239 Posted October 6, 2017 Posted October 6, 2017 Why not use host mode? FYI - the Bind on local Network setting is only an exclusion filter to eliminate other addresses. You can empty out the field and this should still be true: Now i can access my server with the correct IP Adress.
