Dizzy49 99 Posted October 5, 2017 Posted October 5, 2017 More than once I have gone into a tv series to mark it as Favorite or something and I am BLASTED by the theme music that is SO LOUD not only does it scare the crap out of me, but it's so loud that you can't even understand it. PLEASE normalize the audio for the theme songs so they are at least CLOSE. 1
bigjohn 754 Posted October 7, 2017 Posted October 7, 2017 If you are using the TV Theme Songs plugin, there is an option for normalization at the bottom of that plugin's settings page. To get them normalized they have to be re-downloaded by the plugin, so you would have to delete them all from the plugin settings page and then delete the theme music files in your file system.
Dizzy49 99 Posted October 9, 2017 Author Posted October 9, 2017 Media Center Master downloads the theme songs and trailers for me. I'll check out the plugin to see if that helps.
