SWKerr 4 Posted October 5, 2017 Posted October 5, 2017 I have just purchased a HDHR Extend that will encode h.264 on the device instead of using cpu. I will still have 2 other HDHR Connects that do not support this feature. Is there a way to force Emby to use the HDHR Extend as the preferred tuner and only select the HDHR Connects when the extend is not available?On SageTV there is a concept call Tuner Merit that allows you to rank your preferred tuner. Anything similar on Emby? 1
Luke 42243 Posted October 5, 2017 Posted October 5, 2017 No, but it's a good idea for the future. For now you can just remove all your tuners and add them back, making sure to add the new one first.
bungee91 133 Posted October 5, 2017 Posted October 5, 2017 I had asked this some time ago and received this reply: Emby sorts the tuners by IP address - so if you want to have them used in a specific order just assign a lower fixed IP to the one you want to use first. For example: Tuner 1 - 192.168.0.10 Tuner 2 - 192.168.0.11 AFAIK there is no way to manually order the tuner priority - maybe a feature request? http://https://emby.media/community/index.php?/topic/40655-tuner-priority-listing/ Is that still the case, or correct as well?
Luke 42243 Posted October 5, 2017 Posted October 5, 2017 I had asked this some time ago and received this reply: http://https://emby.media/community/index.php?/topic/40655-tuner-priority-listing/ Is that still the case, or correct as well? I never gave that response and I have never tested that kind of ordering with IP address so I really cannot comment on that.
bungee91 133 Posted October 5, 2017 Posted October 5, 2017 I never gave that response and I have never tested that kind of ordering with IP address so I really cannot comment on that. Well clearly it wasn't your words , that's why I asked if that was even correct? I just wanted to sort information that is searchable, and that was a response I received for this kind of feature request almost a year ago at this point. If new one first gets priority, then that is the confirmed answer.
