SHSPVR 125 Posted October 3, 2017 Posted October 3, 2017 (edited) Here Video of the problem seem be only doing at Emby forum no other site forum dose this Noyr I run Windows 10 with Edge I all ready try with and with out Logitech G15 Gaming keyboard software https://www.youtube.com/watch?v=atyD9sxM_sc&feature=em-upload_owner Edited October 4, 2017 by SHSPVR
Abobader 3485 Posted October 4, 2017 Posted October 4, 2017 Good day, Can you try to disable the LGS and see if that fix the problem? I use corsair gaming keyboards without any problem. My best
SHSPVR 125 Posted October 4, 2017 Author Posted October 4, 2017 (edited) Did you not read my post I try with and with out Logitech G15 Gaming keyboard software Are you using Windows10 RedStone 3 ? and using Edge Edited October 4, 2017 by SHSPVR
Abobader 3485 Posted October 4, 2017 Posted October 4, 2017 Good day, Sorry regarding not fully read your post, I was focus on the video. No to both. This issue best handling at the logitech forum support. My best
SHSPVR 125 Posted October 4, 2017 Author Posted October 4, 2017 (edited) Ok then I check my Laptop as it had the older ver of Windows 10 with Edge Edited October 4, 2017 by SHSPVR
SHSPVR 125 Posted October 4, 2017 Author Posted October 4, 2017 Look like it a Bug in Windows 10 RS3 aka Fall Creators Update I sent off a bug report on that as my Laptop with Windows 10 builder 15063.608 works fine
Abobader 3485 Posted October 4, 2017 Posted October 4, 2017 Look like it a Bug in Windows 10 RS3 aka Fall Creators Update I sent off a bug report on that as my Laptop with Windows 10 builder 15063.608 works fine Thanks for the update, well done.
