FunkadelicRelic 10 Posted October 3, 2017 Posted October 3, 2017 Hi all. I'm having trouble with the Emby app for Android TV on my Sony Bravia (2015) TV. I have the app installed and can successfully login to my server (Reverse Proxied) and browse my media. However, certain files refuse to play. I start the movie and the spinning loading icon continues to spin while nothing loads. I then have to force close the app. It's strange because some media will work fine, others will not. For reference, I tried the Android, iOS and Chrome apps and all work perfectly. Those devices are all on the same WiFi network and even the videos that will not play on ATV will play just fine on them. It seems localized to my ATV app. Has anyone seen this issue before? I've tried lowering the bitrate to see if that helps but no joy.
CBers 7554 Posted October 3, 2017 Posted October 3, 2017 Ensure the DEBUG option is on in the ATV app and then you can use the SEND LOGS option from within the app. If you need to supply server logs read this guide: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ 1
maegibbons 1287 Posted October 3, 2017 Posted October 3, 2017 Also post here ffmpeg logs for the failed playbacks. Krs Mark
FunkadelicRelic 10 Posted October 3, 2017 Author Posted October 3, 2017 Thanks @@CBers and @@maegibbons - attached is my server log. There was no associated ffmpeg log file. I started the show at 12:14 GMT today, left it spinning for 3 minutes and backed out while it crashed. The show is Turtles (1x03) and the profile was 'Kids' accessing from my Sony Bravia TV on last octet IP .109. Cheers. emby-server-log.txt
FunkadelicRelic 10 Posted October 3, 2017 Author Posted October 3, 2017 I've just sent logs through the client too. Hope that helps. Regards. Tom. 1
CBers 7554 Posted October 3, 2017 Posted October 3, 2017 I've just sent logs through the client too. Hope that helps. Hopefully @@ebr can check them out for you. 1
ebr 16337 Posted October 3, 2017 Posted October 3, 2017 Unfortunately, I cannot see the playback issue in your log. Is it possible to try the beta version to see if it behaves differently?
FunkadelicRelic 10 Posted October 3, 2017 Author Posted October 3, 2017 Unfortunately, I cannot see the playback issue in your log. Is it possible to try the beta version to see if it behaves differently? Thanks @@ebr - I signed up to the beta a few hours ago so I'll go check to see if it has installed yet and give it a try.
FunkadelicRelic 10 Posted October 3, 2017 Author Posted October 3, 2017 OK. The weirdness continues. I have reconfigured my network to take my reverse proxy out of the equation (direct to IP and 8086) and lo and behold, everything streams. This has to be an issue with my reverse proxy. I have another issue open at the below URL, it would be awesome if anyone has any suggestions. Thanks again for all your help so far. https://emby.media/community/index.php?/topic/51307-Emby-via-reverse-proxy-and-internal-network-settings
FunkadelicRelic 10 Posted October 7, 2017 Author Posted October 7, 2017 Bumping as I've discovered this is probably not related to my reverse proxy. I've discovered that if I install MX Player and set Emby to use it as an external player, everything works flawlessly. I'd love to get the stock player working. Is there anything I can do to help progress this issue? The thread I posted above has more details and logs if that is useful?
CBers 7554 Posted October 7, 2017 Posted October 7, 2017 Is that on the beta version? Did you Send Logs in the app again? If not, do so and post here to let @@ebr know what time you sent the logs and what user was logged in. 1
FunkadelicRelic 10 Posted October 7, 2017 Author Posted October 7, 2017 This is on both stable and beta. I'll get some logs uploaded a little later today and let you know. Thanks for your help.
FunkadelicRelic 10 Posted October 9, 2017 Author Posted October 9, 2017 Hi @@CBers - I've just reverted the external player back to using the default player and tried to play one of the videos that fails. Sent the debug logs from the app. The video was attempted at 10:24 GMT with the user 'Tom'. Hope this helps to shed some light on the issue. Regards. 1
FunkadelicRelic 10 Posted October 9, 2017 Author Posted October 9, 2017 @@ebr - sorry, forgot to copy you in on this aswell.
ebr 16337 Posted October 9, 2017 Posted October 9, 2017 Looks like it is trying to play the item in VLC and it simply never starts playing. Can you show us the media info from the web app on this item? Also, have you tried using the "Playback Correction" menu item while it is sitting there trying to play?
FunkadelicRelic 10 Posted October 9, 2017 Author Posted October 9, 2017 I can grab the media info over the next couple of days. Thanks. I tried the playback correction and it seems to temporarily play the video but then it crashes after a few minutes.
FunkadelicRelic 10 Posted October 9, 2017 Author Posted October 9, 2017 Back out of the video, spinny circle, keep pressing back and the app prompts to force close. I can usually start two videos with playback correction before it starts misbehaving.
FunkadelicRelic 10 Posted October 12, 2017 Author Posted October 12, 2017 @@ebr - Sorry for the delay getting back to you. Below is the media info for one of the videos that fails. Media Info Video Codec H264 AVC Yes Profile High Level 41 Resolution 1280x720 Aspect ratio 16:9 Anamorphic No Interlaced No Framerate 23.9760246 Bitrate 2546 kbps Bit depth 8 bit Pixel format yuv420p Ref frames 1 NAL 4 Audio Codec AC3 Layout 5.1 Channels 6 ch Bitrate 384 kbps Sample rate 48000 Hz Default Yes Title Dolby Digital 5.1 Default Container mkv
maegibbons 1287 Posted October 12, 2017 Posted October 12, 2017 Can you post a copy of this media somewhere for us to download? We can then validate the failure on more than one device and see if we can help come up with answers. Krs Mark
FunkadelicRelic 10 Posted October 12, 2017 Author Posted October 12, 2017 I could but not sure it will help to be honest - it's not just this video, it's nearly everything in my library.
CBers 7554 Posted October 12, 2017 Posted October 12, 2017 I could but not sure it will help to be honest - it's not just this video, it's nearly everything in my library. Create a sample of a few videos that fail and we can test. If they fail, then it's Emby, if not, it's something localised to your setup. 1
FunkadelicRelic 10 Posted October 12, 2017 Author Posted October 12, 2017 I think it is a combination of those things @@CBers - I run through a reverse proxy. When I set the Android TV client to point directly at the server, everything works. When I switch back to the reverse proxy, the issues start. However, the reason I don't believe it is reverse proxy related 100%, is that I can stream everything through the reverse proxy if I use the external player in Emby for Android TV, and all my other clients work perfectly through the reverse proxy. It just seems to be an issue when using the built-in Android TV client through the reverse proxy.
CBers 7554 Posted October 12, 2017 Posted October 12, 2017 Are you using g NGINX? Perhaps have a read of @@Swynol's NGINX thread, in case you see something awry. https://emby.media/community/index.php?/topic/47508-how-to-nginx-reverse-proxy/
