Subtitles are loaded on the second try (same problem)
Angelblue05
It could be direct playing + trying to pull down a subtitle externally, which is resulting in on the fly extraction. Just like the other user this extraction is probably too slow for his environment thus we need a better way.
But that is handled via Kodi. The add-on doesn't track subtitles except external ones when direct playing.
@@Paxalou
So, are you transcoding? Just to confirm it's the same issue reported previously, thank you.
Yes, my problem (subtitles are loaded on the second try) happens only when transcoding.
(And I can add that sometimes subtitles are loaded on the third or fourth time...)
EDIT : And I noticed that PGS subtitles don't have this problem. It's only SRT subtitles.
Edited by Paxalou
  • Like 1
Angelblue05
Well, I'd suggest you disable subtitles extraction on your server since it doesn't function well enough. In your server dashboard > Transcoding > Disable Allow subtitles extraction on the fly (should be the last option in the page).
Try playback, does it resolve your issue with subtitles?
Guest
