randomevents 38 Posted October 2, 2017 Posted October 2, 2017 I used to have to do this manually in SQL all the time for Plex, i didn't think that would work with the way Emby handles things. Well worth the five bucks. As for the issue, clicking on TImelord or it's settings in plugins throws an error. It occurred to me to look in schedule tasks (it's running now) and start it from there. Is the former expected behavior?
BeppoMonkeyBoy 98 Posted October 2, 2017 Posted October 2, 2017 There is no settings to be set, (I might put in an info page at some point), simply running the task does the work.
Happy2Play 9814 Posted October 2, 2017 Posted October 2, 2017 (edited) There is no settings to be set, (I might put in an info page at some point), simply running the task does the work. I reported in other topic but the byperlinks when clicking on plugin and the notification are none existant. Edited October 2, 2017 by Happy2Play
BeppoMonkeyBoy 98 Posted October 2, 2017 Posted October 2, 2017 I reported in other topic but the byperlinks when clicking on plugin and the notification are none existant. Should be fixed now,
