Tur0k 148 Posted October 1, 2017 Posted October 1, 2017 Hey guys, I have been trying to find a cheaper solution than standing up full PCs in every room that I need to stream to. I picked up a mibox (android TV) and was having a very good experience until recently. About 2 weeks ago live tv became unreliable. Emby tunes to the channel we want then after a minute playback stops. I will try to figure out how to export logs from this mibox. Sent from my iPhone using Tapatalk
CBers 7554 Posted October 1, 2017 Posted October 1, 2017 Ensure the DEBUG option is on in the ATV app and then you can use the SEND LOGS option from within the app. If you need to supply server logs read this guide: https://emby.media/community/index.php?/topic/790-how-to-report-a-problem/ 1
Solution Tur0k 148 Posted October 22, 2017 Author Solution Posted October 22, 2017 (edited) I figured it out after looking at my unifi controller. the app was pausing and buffering pretty constantly. I found that I needed to turn down the bit-rate in the app to (21Mbps) below what the controller showed the device's throughput Rx statistics was (24 Mbps). Edited October 22, 2017 by Tur0k 3
