ghostquito 6 Posted October 1, 2017 Posted October 1, 2017 The Guide is awesome but there are two things that would put it over the top. 1) The ability to group channels into custom categorizes, and have the categories all grouped together in the guide. 2) The ability to add more info to the Channel Name. Currently if you have a Image it doesn't show any text. If you don't have image the text is limited to a certain amount of characters Ideally you could have a image, text, and add change/add custom channel #s. I believe the text being limited can be solved with CSS but it's not working for me. I added this to the branding section of the server. .guideChannelName { max-width:90%} Thanks!
Happy2Play 9811 Posted October 1, 2017 Posted October 1, 2017 (edited) The Guide is awesome but there are two things that would put it over the top. 1) The ability to group channels into custom categorizes, and have the categories all grouped together in the guide. 2) The ability to add more info to the Channel Name. Currently if you have a Image it doesn't show any text. If you don't have image the text is limited to a certain amount of characters Ideally you could have a image, text, and add change/add custom channel #s. I believe the text being limited can be solved with CSS but it's not working for me. I added this to the branding section of the server. .guideChannelName { max-width:90%} Thanks! I don't have live tv to test but have you tried? .guideChannelName { max-width:90% !important} Edited October 1, 2017 by Happy2Play
Happy2Play 9811 Posted October 1, 2017 Posted October 1, 2017 Since default code and custom code both load you have to add "!important" for higher priority.
ghostquito 6 Posted October 1, 2017 Author Posted October 1, 2017 I'm assuming that setting is only for the web-ui. It doesn't do anything for xbox one or roku? Is there anyway to change it on apps?
