catso 0 Posted October 1, 2017 Posted October 1, 2017 Running Emby Version 3.2.32.0 My files are mainly mkv Running Emby for Media Center on a number of machines Fast Forward and Rewind have stopped working not sure if it was after i switched on premier or not. If have read many posts and have tried refreshing the mediainfo There was a thread mentioned setting paths but i couldnt find the actual thread that discussed the paths
Luke 42237 Posted October 1, 2017 Posted October 1, 2017 hi @@catso, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
catso 0 Posted October 1, 2017 Author Posted October 1, 2017 OK have attached Server log from Media Browser Classic MBClassic-2102017bb13f35a761e458f8cfb28f30371d4b4.log
Luke 42237 Posted October 1, 2017 Posted October 1, 2017 hi @@catso, what's happening is it is streaming through emby server: 2017-10-02 07:28:44.2723,Info,,Internal Player about to play 1 - The Holy Trinity(http://192.168.0.112:8096/emby/videos/faf42d70df8936190e4dacdd0b23914e/stream.asf?DeviceId=198dad94debe438abe4c92527c46bbf3&MediaSourceId=faf42d70df8936190e4dacdd0b23914e&VideoCodec=msmpeg4&AudioCodec=wmav2&AudioStreamIndex=1&VideoBitrate=29872000&AudioBitrate=128000&MaxAudioChannels=2&api_key=bfb5731ac6354242a95c74cdbcc5b52c&CopyTimestamps=false&ForceLiveStream=false) ,1,Application Since WMC has limited streaming capabilities, this results in sub-par playback. What you need to do is configure your server libraries so that the machine running Emby for WMC can directly access the files over your network. If you do that then this issue will go away. @@Teddy in case you have any wmc tips
catso 0 Posted October 2, 2017 Author Posted October 2, 2017 Thanks , Just wondering if you can point me to directions on how to configure the server libraries?
catso 0 Posted October 2, 2017 Author Posted October 2, 2017 I have my media data on a NAS and used the Mapped drive on the server instead of the NAS network address, once i changed that it started working......
Luke 42237 Posted October 3, 2017 Posted October 3, 2017 @@catso, we highly discourage using windows mapped drives. windows will disconnect them when the drives idle and emby server will not be able to connect to them. inevitably you will just end up coming back here telling us that something isn't working. I would use the original network address in emby server.
jachin99 88 Posted October 5, 2017 Posted October 5, 2017 I'll chime in here, I've found that turning power management features off in windows usually goes a long way. My server never sleeps, and when I am able I'm going to build a dedicated media player PC so that all it does is serve files.
