Hydro 5 Posted October 1, 2017 Posted October 1, 2017 Hi I try to create a plugin for Emby server. Basically this plugin must send clients state to my home automation system. For exemple if I watch movie through emby theater, this plugin send to my HA that Emby theater is playing, movie informations... I think it's like what happen to the server main page, when you connect or watch something, it appears on the client tile. Anyway, I try the last documentation but I've got an error when I try to go to the setting page of my plugin. Here my github : https://github.com/Hydro8/Emby Here the error : https://i.imgur.com/dgxFdNJ.jpg I use Roku plugin as base as you can see. Maybe something with name but I don't find the problem. If someone can help me Sent from my ONEPLUS A3003 using Tapatalk
Luke 42237 Posted October 1, 2017 Posted October 1, 2017 Make sure to mark the web resources as Embedded Resources. FYI, I notice you're using visual studio 2015. If you wish to submit to the emby plugin catalog then you'll need to follow the latest plugin instructions: https://emby.media/community/index.php?/topic/50462-updated-plugin-docs-for-net-core/ Thanks.
