ShadowBlade72 22 Posted October 1, 2017 Posted October 1, 2017 So I'm banging my head against the wall trying to figure this out. Essentially, my media library got scanned. It found P90X (not on tvdb) and it found my Looney tunes Golden Collection (also not on tvdb). They both got tagged at **403 Not Permitted**. How can I split them so I can manually identify them? There is no option that I can find to split these into two separate items. Also, it appears that some items got "absorbed" into P90X.
Happy2Play 9802 Posted October 1, 2017 Posted October 1, 2017 What is your exact folder structure? Anomilies like this happen with nested folder structure in Content Type TV.
ShadowBlade72 22 Posted October 1, 2017 Author Posted October 1, 2017 (edited) TV Shows > Looney Tunes Golden Collection > Volume 1 TV Shows > Looney Tunes Golden Collection > Volume 2 TV Shows > Looney Tunes Golden Collection > etc. etc. TV Shows > P90X I ended up going in and editing the metadata for P90X through the server settings panel to remove the TVDB entry, then performed a library scan. It seems to have resolved the issue. Would have much preferred a "Split" option for media mismatches that end up with multiple series stuck under a single title, but I'm glad I got it figured out. Appreciate the response either way. Cheers! Edited October 1, 2017 by ShadowBlade72
Luke 42197 Posted October 1, 2017 Posted October 1, 2017 In emby library setup you also could have disabled grouping for that library. 1
chrisfoulds1986 1 Posted November 23, 2021 Posted November 23, 2021 sorry to bump an old thread, but i found if you go to the file folders, find the "Season" nfo file, and edit it to reflect the correct season, it seems to resolve and split the series back up. 1
