fbrassin 47 Posted September 30, 2017 Posted September 30, 2017 (edited) Hello, sometimes emby does not responde if i try to connect via web or via app, also if i am in local. The only way to make it work is to manually restart it. I use ubuntu. On terminal if i give: ps -aux | grep emby I have: root 2513 0.0 0.0 86188 1424 ? Ss set29 0:00 su -s /bin/sh -c umask $0; exec "$1" "$@" emby -- 002 env MAGICK_HOME=/usr/lib/emby-server MAGICK_CODER_FILTER_PATH=/usr/lib/emby-server/x86_64-linux-gnu/EmbyMagick-6.9.6/modules-Q8/filters MAGICK_CODER_MODULE_PATH=/usr/lib/emby-server/x86_64-linux-gnu/EmbyMagick-6.9.6/modules-Q8/coders MONO_THREADS_PER_CPU=250 MONO_GC_PARAMS=nusrsery-size=128m LD_LIBRARY_PATH=/usr/lib/emby-server/x86_64-linux-gnu /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh emby 2582 1.0 15.4 2362776 615672 ? Ssl set29 11:03 /usr/bin/mono-sgen --optimize=all /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -restartpath /usr/lib/emby-server/restart.sh fabio 28578 0.0 0.0 11804 920 pts/3 S+ 15:40 0:00 grep --colour=auto emby So it seems to be running. Here is the log. Now is 15.45 while the log stops at 13.16. So it seems emby i stuck Any idea to solve this? server-63642326400.txt Edited September 30, 2017 by fbrassin
