pellinore 3 Posted September 29, 2017 Posted September 29, 2017 (edited) Hi I have some syncs setup for new shows but I have just found out it is syncing over Mobile Data. I have Offline Sync set to Sync only on Wifi. Is there any other settings I need to set? Edited September 29, 2017 by pellinore
Luke 42244 Posted September 29, 2017 Posted September 29, 2017 Thats all you need to do. Why do you think it's seeking over mobile?
pellinore 3 Posted September 29, 2017 Author Posted September 29, 2017 I just had it downloaded 3.8GB on Mobile, when I noticed it there was a notification saying it was downloading. I do believe it started on Wifi but did not finish when I left the house.
Luke 42244 Posted September 29, 2017 Posted September 29, 2017 Ok yes that would be the reason why. We have to check again in between each download. thanks.
revengineer 142 Posted September 29, 2017 Posted September 29, 2017 Ouch, this is a problem. I would hate to pile up cell data overages because I had to grab my phone and leave the house while a transfer is in progress. Since the movie files are large, I actually suggest to stop transfers as soon as the wifi network drops. This is a common issue and has been solved by other developers. I assume this is not hard.
Luke 42244 Posted September 29, 2017 Posted September 29, 2017 They'll stop anyway due to the sudden network disconnection. The only open issue is that they'll catch the failure and move onto the next download without re-checking the network.
pellinore 3 Posted September 29, 2017 Author Posted September 29, 2017 This was for a few TV shows, so is there anyway to have it recheck the network after a failure?
Luke 42244 Posted September 29, 2017 Posted September 29, 2017 Yes we will look into this for the next release of the app. thanks.
Bazzu85 22 Posted October 12, 2018 Posted October 12, 2018 Hi, I'm experiencing now the issue with last version.. emby android download new episode also on mobile and only wifi is checked.. is still buggy?
Luke 42244 Posted October 12, 2018 Posted October 12, 2018 It's resolved for the next app update. Thanks.
Bazzu85 22 Posted October 12, 2018 Posted October 12, 2018 (edited) ETA? because is a BIG problem for who have limited data plan.. or can you provide a temporary apk? It's resolved for the next app update. Thanks. Edited October 12, 2018 by Bazzu85
Bazzu85 22 Posted October 12, 2018 Posted October 12, 2018 ok, thanks man.. No ETA but hopefully soon. Thanks.
Luke 42244 Posted October 14, 2018 Posted October 14, 2018 There is a beta release available, 3.0.18, and it has the fix for this. Please reconfigure your download settings. Thanks.
