bernado99 5 Posted February 18, 2018 Posted February 18, 2018 Thanks, in case it matters the phone is on Android 6.
Luke 42241 Posted March 4, 2018 Posted March 4, 2018 I'll do another round of bluetooth testing, thanks.
bernado99 5 Posted March 4, 2018 Posted March 4, 2018 I'll do another round of bluetooth testing, thanks. To be honest Luke I have a feeling it's something peculiar about my phone or else many others here would be reporting it, the result is extreme. The problem is my phone is a Honor 5 which uses a (horrible) Huawei skinned version of Android, I run it with Nova launcher to mitigate that but of course that's only a cosmetic solution and the Huawei EMUI system is still running. Unless you're unlucky enough to have a Huawei phone this is something you may have trouble replicating.!
flowlee 1 Posted March 5, 2018 Posted March 5, 2018 I can replicate the problem too, and in my case it's definitely a problem with the phone. I use a Vernee Apollo Lite and the playback is as described. With any other Android device I was able to test there's no problem with bluetooth audio.
bernado99 5 Posted March 5, 2018 Posted March 5, 2018 I can replicate the problem too, and in my case it's definitely a problem with the phone. I use a Vernee Apollo Lite and the playback is as described. With any other Android device I was able to test there's no problem with bluetooth audio. Comparing the specs between our two phones I can't really see any common denominator other than Bluetooth 4.1, which can't be anything significant I would have thought. Good to know I'm not alone though.
Qriz75 1 Posted March 8, 2018 Posted March 8, 2018 I can report that the beta fixed the choppy playback for me It also fixed an unrelated issue where the playback stopped after every track (only happened on certain albums) Android 6.0 on an LGMS631 Server 3.3.0 the only thing that is a problem now: I can't seem to jump to a spot in the track by tapping the progress bar. Not a big deal for music playback, but if you have an 8hr audiobook and have to find your spot this is not going to be fun.
Luke 42241 Posted March 8, 2018 Posted March 8, 2018 Thanks for the feedback. We'll take a look at the progress bar.
Luke 42241 Posted March 8, 2018 Posted March 8, 2018 @@flowlee @@bernado99 When this happens, what kind of music files are you playing?
Qriz75 1 Posted March 8, 2018 Posted March 8, 2018 @@flowlee @@bernado99 When this happens, what kind of music files are you playing? any playback of mp3 files ... I checked it on music as well as audiobooks(library doesn't show up in the beta app). I created a playlist and behaviour is the same.
flowlee 1 Posted March 8, 2018 Posted March 8, 2018 For me it's also mp3 files. And the result is the same regardless of whether the file is synced or streamed. I can report that the beta fixed the choppy playback for me It also fixed an unrelated issue where the playback stopped after every track (only happened on certain albums) Android 6.0 on an LGMS631 Server 3.3.0 the only thing that is a problem now: I can't seem to jump to a spot in the track by tapping the progress bar. Not a big deal for music playback, but if you have an 8hr audiobook and have to find your spot this is not going to be fun. What version are you using?
Qriz75 1 Posted March 8, 2018 Posted March 8, 2018 For me it's also mp3 files. And the result is the same regardless of whether the file is synced or streamed. What version are you using? the beta app is 1.5.56g
flowlee 1 Posted March 8, 2018 Posted March 8, 2018 the beta app is 1.5.56g Hmmm... Is that Android? I'm on 2.9.90, so maybe you are on Android TV?
Qriz75 1 Posted March 8, 2018 Posted March 8, 2018 yes indeed ... I followed a link and that was downloaded .... Is there a beta for Emby android ?
Luke 42241 Posted March 8, 2018 Posted March 8, 2018 https://emby.media/community/index.php?/topic/24350-android-open-beta-testing/?view=getnewpost
Qriz75 1 Posted March 8, 2018 Posted March 8, 2018 so Emby for Android(beta now) is choppy again ... generally sluggish... Emby TV performs great but isn't meant to be displayed on a phone.. but I rather deal with that than with choppy music. it isn't as noticeable on Audiobooks, so I'll use Emby for Android for that and have the ability to tap on the progress bar. will try any new versions that come out and report back
bernado99 5 Posted March 11, 2018 Posted March 11, 2018 @@flowlee @@bernado99 When this happens, what kind of music files are you playing? Just tried again with the latest release and the odd slow down effect has now gone so hurrah! Trouble is music playback is now choppy and equally unlistenable so boo! Tried this on mp3 and wav files with the same result.
bernado99 5 Posted March 11, 2018 Posted March 11, 2018 @@flowlee @@bernado99 When this happens, what kind of music files are you playing? Just requoting rather than editing my previous post to raise another flag in case you're monitoring Luke, but a very happy update to report. I factory reset my phone which trigured a system upgrade to Android 7 (EMUI 5) and everything's now good so happy days. We'll never know if it was the reset or system upgrade that cured it but all is well, it might be worth others who are affected trying a factory reset if they can stomach it. I need to put back the apps I was running on the phone so will update here if I identify any resulting problems. Thanks
flowlee 1 Posted March 11, 2018 Posted March 11, 2018 Just tried again with the latest release and the odd slow down effect has now gone so hurrah! Trouble is music playback is now choppy and equally unlistenable so boo! Are you using the beta again? The results you are describing sound like the behavior of the stable release. I factory reset my phone which trigured a system upgrade to Android 7 (EMUI 5) and everything's now good so happy days. We'll never know if it was the reset or system upgrade that cured it but all is well, it might be worth others who are affected trying a factory reset if they can stomach it. I can also confirm that on my Android 7 phone everything is working just fine, so that could be something to look at.
bernado99 5 Posted March 11, 2018 Posted March 11, 2018 Are you using the beta again? The results you are describing sound like the behavior of the stable release. I can also confirm that on my Android 7 phone everything is working just fine, so that could be something to look at. This was with the stable release (non-beta) as you say. I've just put the 'stable' release on my partner's phone (which is the same as mine) as an experiment though it's not running the same apps as mine was. I seem to recall she had to reset it recently though it's still on Android 6, the audio playback issues are problematic in exactly the same way as it was on my phone pre o/s upgrade so maybe it is something connected to Android 6. Thanks
wedgekc 12 Posted July 17, 2018 Posted July 17, 2018 I am having a problem with this again after updating to 3.0.00. I get stuttering every 5-10 seconds using my Bluetooth headset, after plugging in wired headphones music plays normally. Reverting back to 2.9.92 also fixes the Bluetooth problem and music plays normally. Xiaomi Mi Max 2, Android 7.1.1 Thanks
sk1deep 0 Posted August 3, 2018 Author Posted August 3, 2018 Great through the browser on phone, weird and choppy through the app on phone.
Luke 42241 Posted August 3, 2018 Posted August 3, 2018 Great through the browser on phone, weird and choppy through the app on phone. What device are you on?
sk1deep 0 Posted August 4, 2018 Author Posted August 4, 2018 (edited) What device are you on? When I started this topic I was on an LG k20 and the issue followed me to an LG stylo 3 and the problem was way worse on both phones at that time. The song would start out fine and progress to being unlistenable with extreme choppiness and distortion. An update fixed the problem and I hadn't tried it since then. Just renewed my gym membership and of course wanted to use my favorite app to listen to my tracks on my home pc at the gym and I see the issue is back just nowhere near as bad as it was before. Noticeable stutters but nothing near as bad as the original problem. Tried it over 4g and wifi to see if that was the issue still frequent skips and as I said it only occurs through the app not through the browser. I don't really lose any features using it through the browser on my phone so it's not the worst thing in the world but of course the app is smoother. Thanks for all the hard work! Edited August 4, 2018 by sk1deep
