FunkadelicRelic 10 Posted November 1, 2017 Author Posted November 1, 2017 @@FunkadelicRelic - That's why I have 3 Shield TV's They are the best Android TV devices on the market. The HDHomeRun devices work well with Emby. Perfect, that's exactly the one I'm looking at. I will most certainly be buying another to replace my Roku. Thanks again for all your help mate, I really do appreciate it. 2
CBers 7556 Posted November 1, 2017 Posted November 1, 2017 Thanks again for all your help mate, I really do appreciate it. No worries, we're here to try and help
vortexdk 1 Posted July 11, 2020 Posted July 11, 2020 I'm sorry to resurrect such an old thread, but I can find any other posts concerning using HA proxy. I believe I have a slightly different problem. When if try to log in from outside my network, I am able to login and play any file from the browser, but from the android app I get an invalid username and password. but it looks like you are able to log in from all platforms on WAN, so I was hoping maybe you could help me understand how you were able to make it work. I'm am configuring HA proxy on my pfsense box via the GUI. I hope someone can help me.
Luke 42246 Posted July 12, 2020 Posted July 12, 2020 On 7/11/2020 at 7:41 AM, vortexdk said: I'm sorry to resurrect such an old thread, but I can find any other posts concerning using HA proxy. I believe I have a slightly different problem. When if try to log in from outside my network, I am able to login and play any file from the browser, but from the android app I get an invalid username and password. but it looks like you are able to log in from all platforms on WAN, so I was hoping maybe you could help me understand how you were able to make it work. I'm am configuring HA proxy on my pfsense box via the GUI. I hope someone can help me. Hi, have you compared to the configurations in this topic?
pir8radio 1313 Posted July 13, 2020 Posted July 13, 2020 On 10/1/2017 at 1:36 PM, FunkadelicRelic said: Below is my HAProxy config. I have a bunch of other services running through this but I have deleted the relevant lines. Also replaced my current WAN address with [ExternalIP] - left the internal in there. # Automaticaly generated, dont edit manually. # Generated on: 2017-09-29 15:16 global maxconn 10000 stats socket /tmp/haproxy.socket level admin uid 80 gid 80 nbproc 1 chroot /tmp/haproxy_chroot daemon tune.ssl.default-dh-param 2048 server-state-file /tmp/haproxy_server_state listen HAProxyLocalStats bind 127.0.0.1:2200 name localstats mode http stats enable stats admin if TRUE stats uri /haproxy/haproxy_stats.php?haproxystats=1 timeout client 5000 timeout connect 5000 timeout server 5000 # Frontend on internal interface frontend FE-MGMT-443 bind 10.8.20.254:443 name 10.8.20.254:443 ssl crt /var/etc/haproxy/FE-MGMT-443.pem crt /var/etc/haproxy/FE-MGMT-443 mode http log global option http-keep-alive option forwardfor acl https ssl_fc http-request set-header X-Forwarded-Proto http if !https http-request set-header X-Forwarded-Proto https if https timeout client 30000 acl Emby hdr_beg(host) -i emby.domain.com use_backend Emby_http_ipvANY if Emby # Frontend on external WAN interface frontend FE-WAN-443 bind [ExternalIP]:443 name [ExternalIP]:443 ssl crt /var/etc/haproxy/FE-WAN-443.pem crt /var/etc/haproxy/FE-WAN-443 mode http log global option http-keep-alive option forwardfor acl https ssl_fc http-request set-header X-Forwarded-Proto http if !https http-request set-header X-Forwarded-Proto https if https timeout client 30000 acl Emby hdr_beg(host) -i emby.domain.com use_backend Emby_http_ipvANY if Emby backend Emby_http_ipvANY mode http log global timeout connect 30000 timeout server 30000 retries 3 server Emby 10.8.50.224:8096 check inter 10000 looks like the only headers you are passing/setting are http-request set-header X-Forwarded-Proto http if !https http-request set-header X-Forwarded-Proto https if https Take a look at my nginx config and pass/set the same headers.. I dont know the syntax for HA proxy. https://emby.media/community/index.php?/profile/1037-pir8radio/&tab=field_core_pfield_11
vortexdk 1 Posted July 13, 2020 Posted July 13, 2020 thank you very much I was able to pass these two headers: Quote http-request set-header X-Forwarded-Proto http if !https http-request set-header X-Forwarded-Proto https if https I have attached a picture of what it looks like in the GUI if any one is interested. I have since made other changes to accommodate a separate unrelated webserver, this appears to have broken SSL on my local network when I use the URL, IP still works. So I will be doing some more fine tuning. thanks again for the help
