snake98 10 Posted September 28, 2017 Posted September 28, 2017 I have 3 antenna for over the air tv. The guide does not list them in numerical order, but by source i believe. Is there a way to change this?
Luke 42243 Posted September 29, 2017 Posted September 29, 2017 have you tried using the sorting controls behind the 3-dot menu? 1
snake98 10 Posted September 29, 2017 Author Posted September 29, 2017 have you tried using the sorting controls behind the 3-dot menu? Doah, didn't see that, are the same options available on firetv, and Roku?
Solution ebr 16336 Posted September 29, 2017 Solution Posted September 29, 2017 Doah, didn't see that, are the same options available on firetv, and Roku? Both of those apps will use the same setting you set with the web app. You can also modify it on the Fire. The Roku may not have the ability to modify it yet. 1
snake98 10 Posted September 29, 2017 Author Posted September 29, 2017 What was the sort setting on before? recently used.
Luke 42243 Posted September 30, 2017 Posted September 30, 2017 Does that recently used order make sense?
