ifignella 12 Posted October 12, 2017 Posted October 12, 2017 @@ebr, I just tested this and it works fine. My only suggestion would be for the pop up to stay a little longer before closing the item. Not sure if that's controllable or not. For reference, I think Netflix is around a couple mins or so, seems to stay quite a long time. That seems excessive, but maybe 30 seconds so I have enough time to flip over the chair and find the remote.
Jdiesel 1435 Posted October 12, 2017 Author Posted October 12, 2017 @@ebr, I just tested this and it works fine. My only suggestion would be for the pop up to stay a little longer before closing the item. Not sure if that's controllable or not. For reference, I think Netflix is around a couple mins or so, seems to stay quite a long time. That seems excessive, but maybe 30 seconds so I have enough time to flip over the chair and find the remote. I would agree that this time window is a bit short. Otherwise it seems to work well. Thanks again.
