cherup 3 Posted September 28, 2017 Posted September 28, 2017 (edited) I have recorded a .ts container with a h.264 video and ac3 as audio. As I want to play this with my FireTV I have seen that video will be transcoded instead of playing directly. Is there something I can configure that direct play is possible with that device ? Edited September 28, 2017 by cherup
arrbee99 1836 Posted September 28, 2017 Posted September 28, 2017 Not sure if this'll help, unless you've seen it already of course. https://emby.media/community/index.php?/topic/49542-firetv-ts-files-streaming/ Just something I came across.
Solution maegibbons 1287 Posted September 28, 2017 Solution Posted September 28, 2017 (edited) Yes. .ts are always remuxed now because seeking is unreliable within a .ts container Krs Mark Edited September 28, 2017 by maegibbons 1
BAlGaInTl 288 Posted September 28, 2017 Posted September 28, 2017 Is this Live TV that you have recorded with Emby? Or was it from another application? I've set my settings in Live TV to automatically convert to MKV while preserving original audio/video. Seems to be better than transcoding while streaming.
Luke 42245 Posted September 28, 2017 Posted September 28, 2017 @@cherup, does this answer your question? thanks !
cherup 3 Posted September 28, 2017 Author Posted September 28, 2017 Thanks for the answers! I have recorded the .ts files via my Enigma2 receiver - so not via Live TV - so I assume transcoding is normal. Is there a possibility to auto convert these files to MKV via emby ?
Luke 42245 Posted September 28, 2017 Posted September 28, 2017 Indirectly, yes. Check out the folder sync option: https://github.com/MediaBrowser/Wiki/wiki/Folder%20Sync Thanks.
