daeks 1 Posted September 27, 2017 Posted September 27, 2017 Hello together, I am currently investigating Emby to switch over from Plex. Unfortunately I am heavily using ignore files within Plex, which seem to work differently with Emby. In Emby you can only place a static .ignore file in the directory which ignores everything in and below it. Is there a way to apply some more dynamic on it? I need a .ignore file in which I can define which subfolders or filetypes I want to ignore as I only want to ignore some parts of it. If it is currently not possible to do that, I want to raise a feature request for it. 1
