meatchunks 2 Posted September 27, 2017 Posted September 27, 2017 Hello, quick question...is there a way to restrict users from accessing the admin settings? ie: Authenticating with the server with their username and password? Here is my current setup... Emby server with SSL enabled (port 8921 then forwarded to 8096 internal, no issues here), and my ddns name is setup. When a user goes to the DDNS address, they are automatically logged in and can access all the admin settings.
Solution mastrmind11 722 Posted September 27, 2017 Solution Posted September 27, 2017 Hello, quick question...is there a way to restrict users from accessing the admin settings? ie: Authenticating with the server with their username and password? Here is my current setup... Emby server with SSL enabled (port 8921 then forwarded to 8096 internal, no issues here), and my ddns name is setup. When a user goes to the DDNS address, they are automatically logged in and can access all the admin settings. Check the user settings. You have to explicitly make a user an admin. 1
Happy2Play 9802 Posted September 27, 2017 Posted September 27, 2017 Do you have a account that they are accessing that does not have a password (ie the admin account)?
meatchunks 2 Posted September 27, 2017 Author Posted September 27, 2017 Nice thanks guys. Found it under user settings and made the default admin account hidden from login, and then added a password to it. 1
Happy2Play 9802 Posted September 27, 2017 Posted September 27, 2017 Nice thanks guys. Found it under user settings and made the default admin account hidden from login, and then added a password to it. If you still want local access without password you can enable the Easy pin option also.
Luke 42203 Posted September 27, 2017 Posted September 27, 2017 Sounds like you're giving everyone the admin account instead of creating separate users?
meatchunks 2 Posted September 27, 2017 Author Posted September 27, 2017 Sounds like you're giving everyone the admin account instead of creating separate users? No, not my intent. They are all separate users, but they were able to see and login with the default admin account (until I 'hid' it and password protected it). 1
porkbone 48 Posted September 27, 2017 Posted September 27, 2017 Had to give a like for the name @meatchunks
meatchunks 2 Posted September 27, 2017 Author Posted September 27, 2017 @@porkbone haha thanks, porkbone is pretty good too
