Forcesius 0 Posted September 26, 2017 Posted September 26, 2017 HiAfter the new update i cannot get access to schueled task and it freeze. On my server (Synology) can i see emby has closed and after i have start it up again ends with same result. I have also tried to deleted and install emby again but the same happens. i cannot either gets access to plugin refresh it stand at zero and closed again.What to do
Luke 42203 Posted September 26, 2017 Posted September 26, 2017 Hi there, Can you please attach the emby server log? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
Forcesius 0 Posted September 26, 2017 Author Posted September 26, 2017 (edited) here is the log Edited September 26, 2017 by Forcesius
Luke 42203 Posted September 26, 2017 Posted September 26, 2017 @@Forcesius did you forget to attach the log? thanks.
Forcesius 0 Posted September 26, 2017 Author Posted September 26, 2017 yes the first time was a fail . but haven´t you recieved it now?
Luke 42203 Posted September 26, 2017 Posted September 26, 2017 Where did you send it? It should be attached in this thread so that both of us can see it. Click "more reply options" next to the "Post" button.
Luke 42203 Posted September 27, 2017 Posted September 27, 2017 Can you try uninstalling the kodi sync plugin and seeing if this helps at all? the log mostly looks OK to be honest. Thanks !
Forcesius 0 Posted September 27, 2017 Author Posted September 27, 2017 Hi i have tried to uninstall kodi sync but gets the same result. I have attached a new log emby log.zip
solabc16 379 Posted September 27, 2017 Posted September 27, 2017 Hello @@Forcesius I'm usually over on the Synology (https://emby.media/community/index.php?/forum/153-synology/) forum and look after the Synology/XPEnology builds and releases. If possible, can you run the diagnostics and sendlogs utilities, you can find the instructions on the Wiki:- Diagnostics : https://github.com/M...Run-Diagnostics Send Logs : https://github.com/M...us-Support-Logs This will give me some more information to see what is going on with your system; especially as you're saying this happens from a fresh install. Best - James 1
Forcesius 0 Posted September 27, 2017 Author Posted September 27, 2017 Hi james. I dont think i cant get in there. maybe its possible to help over Teamviewer?Emby worked fine before the Newest update.
solabc16 379 Posted September 27, 2017 Posted September 27, 2017 Hello @@Forcesius If you're not familiar with running an SSH session to your NAS, then sure - happy to do a TeamViewer session. Best - James
Forcesius 0 Posted September 27, 2017 Author Posted September 27, 2017 i am beginner in NAS server. I send you a PM
Solution solabc16 379 Posted September 27, 2017 Solution Posted September 27, 2017 For anybody else reading, the issue and solution can be found here: https://emby.media/community/index.php?/topic/40411-xpenology-users-read-me/?p=485640 Best - James 1
