Luke 42234 Posted July 19, 2013 Posted July 19, 2013 https://github.com/MediaBrowser/MediaBr ... Web-Socket I have finally gotten around to this. I would recommend every client get connected to the web socket. There will be more added to it over the next couple days.
Luke 42234 Posted July 19, 2013 Author Posted July 19, 2013 Those who are doing remote control should read the dynamic messages part. Also - playback check-ins can be sent over the web socket, which comes with considerably less overhead then sending the info over the http api. This will allow you to send the info more often. The dashboard uses a five second interval when the web socket is connected. MBT, 2 seconds. The lower the interval the more responsive remote control will feel to the user. For example, sending a seek command to a client. It will occur very quickly, but the client won't get new playback info until the new position has been reported to the server.
Luke 42234 Posted July 19, 2013 Author Posted July 19, 2013 Also I will add notes about the context messages, which I don't think any of you know about at this point. But as the user browses you can send a context message over the web socket so that the server knows where the user is, and can report that to interested parties.
Abobader 3485 Posted July 19, 2013 Posted July 19, 2013 Also I will add notes about the context messages, which I don't think any of you know about at this point. But as the user browses you can send a context message over the web socket so that the server knows where the user is, and can report that to interested parties. Good day Luke, Yes regarding web socket, it will be more lovely if a server admin send a msg for the client "custom one" My best
ebr 16331 Posted July 19, 2013 Posted July 19, 2013 Also I will add notes about the context messages, which I don't think any of you know about at this point. But as the user browses you can send a context message over the web socket so that the server knows where the user is, and can report that to interested parties. MBC sends these now for the current item being viewed. Is it used for anything yet?
Luke 42234 Posted July 20, 2013 Author Posted July 20, 2013 At this point chef is the only one looking at it that i know of, but the web client will eventually i imagine.
Redshirt 1487 Posted July 20, 2013 Posted July 20, 2013 Can you please clarify, what's needed to make the server aware that a client is available to be remotely controlled. I've now got a WebSocket client up and am successfully connecting to the server.
Luke 42234 Posted July 20, 2013 Author Posted July 20, 2013 currently the server thinks any client who is connected via web socket and has correctly identified themselves can be remote controlled. if the need ever arises where you have to specify your capabilities, we'll handle it then.
Redshirt 1487 Posted July 20, 2013 Posted July 20, 2013 oops. My mistake. I was sending the device string rather than device id string in the identify message. Working as expected now.
Luke 42234 Posted July 20, 2013 Author Posted July 20, 2013 i've added both the playback check-ins and context messages. please improve anything you find unclear.
