bluemonkey07 590 Posted September 26, 2017 Posted September 26, 2017 Is it intensional that the auto organise settings page is not accessible in the Android mobile app any longer?
Luke 42243 Posted September 26, 2017 Posted September 26, 2017 You just have to install the auto-organize plugin and then you should be able to get to it.
bluemonkey07 590 Posted September 26, 2017 Author Posted September 26, 2017 (edited) Sorry for not stating what is implied, of course I have the plug-in installed on the server v 3.2.30.0 Android app 2.9.61 I can access ok via the web app Edited September 26, 2017 by Vidman
Luke 42243 Posted September 26, 2017 Posted September 26, 2017 Does it just not show up in the app or are you getting an error?
bluemonkey07 590 Posted September 26, 2017 Author Posted September 26, 2017 (edited) There is no auto organise menu option to access the settings page Edited September 26, 2017 by Vidman
Luke 42243 Posted September 26, 2017 Posted September 26, 2017 Ok, once you have serverĀ 3.2.32, then you'll have the menu option back. thanks.
