FargoPCGuy 0 Posted September 26, 2017 Posted September 26, 2017 The counter for my TV episodes seems to be stuck at 24,999. I have added over 100 episodes since the counter hit 24999, and it still hasn't moved. Is There a Limit? Library scans seemed to have been taking much longer also..
Happy2Play 9802 Posted September 26, 2017 Posted September 26, 2017 Doesn't appear to be a limit. Obviously the more media you have the longer Library scans will take. But what is your definition of longer?
FargoPCGuy 0 Posted September 26, 2017 Author Posted September 26, 2017 Library scans have suddenly jumped from about 4 mins to close to 15, but the do finish. New episodes show up where they are supposed to when viewing the library, but the counter quit ticking at 24999. I have also been trying to add a new media section... after setting it up and hitting save, it does not show up. I go back and try again.....same thing Ryzen 7 1700 @ 3.6 Ghz 16 Gb DDR4 3200 480 Gb SSD 25 Tb Disk Space
Happy2Play 9802 Posted September 26, 2017 Posted September 26, 2017 Library scans have suddenly jumped from about 4 mins to close to 15, but the do finish. New episodes show up where they are supposed to when viewing the library, but the counter quit ticking at 24999. I have also been trying to add a new media section... after setting it up and hitting save, it does not show up. I go back and try again.....same thing Ryzen 7 1700 @ 3.6 Ghz 16 Gb DDR4 3200 480 Gb SSD 25 Tb Disk Space What browser? Do you have another one to test in? Also a log files can assist in troubleshooting this also How to Report a Problem
Luke 42203 Posted September 26, 2017 Posted September 26, 2017 hi @@FargoPCGuy, yes if you attach your server log as requested above we can offer some tips about improving the performance of your library scan. thanks.
Luke 42203 Posted September 26, 2017 Posted September 26, 2017 As far as the episode counter, i'm not even really sure what you mean to be honest. can you show a screenshot? thanks !
