Marc_G 95 Posted October 3, 2017 Posted October 3, 2017 On my end I did the complete Emby removal of tuner and schedules direct information, then updated my hdhomerun firmware, disabled junk channels via the myhdhomerun web interface, then finally in Emby added back the tuner and re entered the schedules direct stuff. Deleted all the recording series plans (which no longer lined up with the channel information) and re-established them all. Sounds like a lot but probably 20 minutes of work [emoji3] So far four or five recording events have gone fine, no problems, YET. If I get any failures I will nuke the system like Doofus did. Doofus, about how long did it itake for you to do a complete rebuild?
Guest asrequested Posted October 3, 2017 Posted October 3, 2017 It took a while. I had some library scanning issues. It kept sticking at 69%. For some reason it didn't like scanning my movie library. I figured out I had to add it with none of the library settings enabled, first, then enable them after the first scan. Other than that, I don't think more than an hour.
