Sayan 0 Posted September 24, 2017 Posted September 24, 2017 (edited) Hi guys, i can't play my files through DLNA on my LG 42LM640S because in less than a minute, i got disconnected from the server. I don't know what to do, can you help me? Log.txt Edited September 24, 2017 by Sayan
Sayan 0 Posted September 24, 2017 Author Posted September 24, 2017 Hi, is that a 2013 model? Yes, i think so
Luke 42239 Posted September 24, 2017 Posted September 24, 2017 Ok well we don't have one of those on hand for testing, but if you can attach the emby server log maybe we can spot something. you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
Sayan 0 Posted September 24, 2017 Author Posted September 24, 2017 I just attacched the log in the first post, is it good?
Luke 42239 Posted September 24, 2017 Posted September 24, 2017 Well it needs to be the complete log file from the time of playback. I don't see any dlna playback attempts in that log. thanks !
Luke 42239 Posted September 24, 2017 Posted September 24, 2017 It looks like it's trying to direct play an mp4. have you checked the supported media formats of the tv to see if it supports this file?
Sayan 0 Posted September 25, 2017 Author Posted September 25, 2017 Yes, if i put the file on an usb pen connected directly to the tv it works. By the way, i have just used an h265 file, where transcoding is needed and the result is the same Log2.txt
