sleepless 2 Posted September 24, 2017 Posted September 24, 2017 Hi, i just report another Bug. If i start to stream any content from my android to my Samsung Blue Ray Player ober DLNA, the stream will never start and a message come up like "Error Network". 3 weeks ago i had used it and it worked perfectly. So good, that i'm have a smile in my face about emby... What's happend? I used emby on a fresh installed Debian 9. the logs say nothing relevant 2017-09-24 15:34:49.879 Info HttpServer: HTTP Response 200 to 192.168.1.122. Time: 38ms. http://192.168.1.120:8096/audio/989205594219bfc92ea9efeed71eb505/stream.mp3?Params=018026d07177d706cfe50a4f211ed2f2;uuid:0bebc201-00c8-1000-9438-5056bfbee6b0;989205594219bfc92ea9efeed71eb505;true;;;;;;;;;;;0;;;;;;;;;989205594219bfc92ea9efeed71eb505;false;;;false;d205239a6cab9aee753e7f4720e680f7;false;;false;false;2017-09-24 15:35:00.584 Info SessionManager: Playback stopped reported by app DLNA 3.2.32.0 playing Break The Rules. Stopped at 0 ms have you fixed it with the 3.2.32.4 emby beta release? If Yes, can you bring it today as final version online? Thanks
Luke 42245 Posted September 24, 2017 Posted September 24, 2017 Hi, this is resolved for the next release, thanks. If you need immediate resolution you can jump on the beta.
sleepless 2 Posted September 24, 2017 Author Posted September 24, 2017 (edited) Hi, this is resolved for the next release, thanks. If you need immediate resolution you can jump on the beta. Two questions: 1. Is the beta a seperate new install or overwrite the existing stable? I ask this because i don't do reconfigure the install every new "beta" and offical Version, apart from loosing the Metadata... 2. Whats happend? Are the reason a update from Samsung or a mistake from your Coder? Thanks for your reply Edited September 24, 2017 by sleepless
Luke 42245 Posted September 25, 2017 Posted September 25, 2017 What operating system and device are you running emby server on?
sleepless 2 Posted September 25, 2017 Author Posted September 25, 2017 It runs on a Debian 9 minimal installation in a VM using ESXi on a Dell Microserver
Luke 42245 Posted September 26, 2017 Posted September 26, 2017 Ok, the beta has some destabilizing changes, so you probably just want to wait for the next stable release. thanks.
sleepless 2 Posted October 1, 2017 Author Posted October 1, 2017 and the next Bug since this stable: music playpack over DLNA to a Denon Receiver randomly stops if i take the next song from a mix... muhahaaaa -> can i get a older stable version? this "stable" version is only full of bugs and many other shit that previously worked fine. "Stable" is the wrong word... PLEASE REVERT or fix the bugs as fast as you can and bring it online... @Luke: ...or make for me a .deb paket from the actually beta, convert it to a "fake" stable to install over the actually stable and send me the fake stable over email, dropbox or something like that....
Luke 42245 Posted October 1, 2017 Posted October 1, 2017 Hi there, please try to refrain from profanity in our community. I apologize for your frustration. You are welcome to try the beta channel if you like. Check out our download page for your operating system to see if it has beta instructions: https://emby.media/download.html Thanks.
sleepless 2 Posted October 1, 2017 Author Posted October 1, 2017 (edited) You are welcome to try the beta channel if you like. Check out our download page for your operating system to see if it has beta instructions: Hmm, i wrote it in another thread so i do copy & paste because the same is happend with the beta... BTW about .net core: it crashes if any other emby version is installed. that's the reason, why i can't test it... it's time to show others my vacation Pictures and i can't due lag/bug/fail from mono, no backup function for remove the stable and join to .net... have you a idea? in a unknown way the service from the beta / netcore will clash with stable service. i try to delete the service, but the netcore service won't start. i think, in a clean system it will work but with a stable preinstalled not.. any idea how i can join? It's possible to create a Backup (save manually folders?? and if yes, wich?)? Edited October 1, 2017 by sleepless
Luke 42245 Posted October 2, 2017 Posted October 2, 2017 3.2.33 is out with the fix for this, thanks.
Solution sleepless 2 Posted October 2, 2017 Author Solution Posted October 2, 2017 3.2.33 is out with the fix for this, thanks. My Hero, Thank you. Now i can use emby :D 1
