bpbastos 1 Posted September 21, 2017 Posted September 21, 2017 (edited) Hi I've been dealing with this problem for some months but can't find any solution, I'm using the lastest stable versions of emby server for linux(3.2.31.0) + tvhclient(1.1.1.0) and tvheadend (4.2.3-85~gda9f14c). The emby server isn't refreshing the guide data, these logs lines seems related to the problem: tvheadend2017-09-21 08:40:25.288 htsp: 192.168.2.14 [ embyserver | TVHclient4Emby-3.2.31.0 ]: Identified as user 'embyserver' (unverified)2017-09-21 08:40:25.288 htsp: 192.168.2.14 [ embyserver | TVHclient4Emby-3.2.31.0 ]: Welcomed client software: TVHclient4Emby-3.2.31.0 (HTSPv20)2017-09-21 08:40:25.289 htsp: 192.168.2.14 [ embyserver | TVHclient4Emby-3.2.31.0 ]: Identified as user 'embyserver'2017-09-21 08:40:25.289 htsp: 192.168.2.14 [ embyserver | TVHclient4Emby-3.2.31.0 ]: Privileges updated Emby2017-09-21 08:40:25.280 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: Used connection parameters: TVH Server = '192.168.2.13'; HTTP Port = '9981'; HTSP Port = '9982'; Web-Root = ''; User = 'embyserver'; Password set = 'True'2017-09-21 08:40:25.280 Info App: [TVHclient] HTSConnectionAsync.authenticate: start2017-09-21 08:40:25.282 Info App: [TVHclient] HTSConnectionAsync.authenticate: authenticated = False2017-09-21 08:40:25.282 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: connection established False Any help would be appreciated. server-63641579938.txt Edited September 21, 2017 by bpbastos
hcgonzalezpr 0 Posted January 26, 2018 Posted January 26, 2018 I'm seen the exact same issue using Emby 3.2.70.0 and tvheadend (4.2.5) / tvheadend (4.3-1006~gd381d71e3).
Luke 42243 Posted January 26, 2018 Posted January 26, 2018 @@hcgonzalezpr, please run the guide refresh, and then when it completes, please attach the information requested in how to report a problem. thanks.
hcgonzalezpr 0 Posted January 26, 2018 Posted January 26, 2018 (edited) @@Luke here's a clean log with debug enable. I restarted and executed the Refresh Guide, after that I access the channel list and saw it empty. 24.4 is the emby server. 24.26 is the tvheadend server. I have confirm the tvheadend works correctly by connecting it to kodi (using the same user as the one used on emby). On Tvheadend I see the exact same as the previous posted. The user on tvheadend is emby and has all enabled except admin access, and I have it setup to use the pass profile. 2018-01-26 13:55:53.019 htsp: ::ffff:192.168.24.4: Identified as user 'emby' (unverified) 2018-01-26 13:55:53.019 htsp: ::ffff:192.168.24.4 [ emby ]: Welcomed client software: TVHclient4Emby-3.2.70.0 (HTSPv20) 2018-01-26 13:55:53.031 htsp: ::ffff:192.168.24.4 [ emby | TVHclient4Emby-3.2.70.0 ]: Identified as user 'emby' 2018-01-26 13:55:53.031 htsp: ::ffff:192.168.24.4 [ emby | TVHclient4Emby-3.2.70.0 ]: Privileges updated server-63652593301.txt Edited January 26, 2018 by hcgonzalezpr
hcgonzalezpr 0 Posted January 26, 2018 Posted January 26, 2018 Hi, did you forget to attach the log? My bad forgot to hit attach after adding it.
Luke 42243 Posted January 26, 2018 Posted January 26, 2018 It completed in three seconds, which is unusually fast. I am not an expert with Tvheadend so i can really only help you from the emby side. We'll need @@Tolotos help. However, I notice you have HD Homerun, is that right?
hcgonzalezpr 0 Posted January 26, 2018 Posted January 26, 2018 However, I notice you have HD Homerun, is that right? That is correct. I added the HDHomerun to it, and it to test,it does show the channels from the HDHomerun. So the issue its related to the TVHEADend plugin, I removed the HDHomerun to keep the troubleshooting easier.
Luke 42243 Posted January 26, 2018 Posted January 26, 2018 Emby has native support for HD Homerun. You don't need to use TV HeadEnd at all. I would go into the server Live TV section and setup your HD Homerun tuner. Please let us know if this helps. Thanks.
hcgonzalezpr 0 Posted January 26, 2018 Posted January 26, 2018 (edited) Emby has native support for HD Homerun. You don't need to use TV HeadEnd at all. I would go into the server Live TV section and setup your HD Homerun tuner. Please let us know if this helps. Thanks. Thanks for the suggestion, I do use the HDhomerun directly, but I also use TVHeadend as proxy for a few iptv channels that don't work as .m3u8 links in emby. It used to work like charm till I updated my ffmpeg to build that has a bug spamming in the piped data. I rebuilt my tvheadend server with a patched ffmpeg and now i got the issue with the plugin not finding the channels. Hopefully @Tolotos will be able to help. Edited January 26, 2018 by hcgonzalezpr
hcgonzalezpr 0 Posted January 29, 2018 Posted January 29, 2018 @@Luke, @@Tolotos, I figured the issue out, for some reason when reading my channels in s TVheadend it dint parse the channel id. So all channels where channel # 0. While this does not cause any issues when connecting from Kodi, the Emby plugin will silently ignore them.
hcgonzalezpr 0 Posted January 29, 2018 Posted January 29, 2018 (edited) How did you determine this? Check all the settings on tvheadend and notice that when adding channels it was not parsing the numbers from the custom piped m3u8 list. Remembered I read this somewhere in the forums while trying to fix my issue. https://emby.media/community/index.php?/topic/24766-tv-headend-live-tv-channels-missing/?p=242918 To confirm, I went and manually set the channel number to something different than zero on Tvheadend and did refresh guide data on emby and the channel showed up. Then I switch one of the channels to zero and did a refresh guide data, and it got removed instantly. Edited January 29, 2018 by hcgonzalezpr
