Teddy 100 Posted February 28, 2014 Posted February 28, 2014 Is there already any fix to solve only 2 backdrops are download with the new beta server? Cheers
saitoh183 137 Posted February 28, 2014 Posted February 28, 2014 did you check the setting to make sure its set to higher?
Koleckai Silvestri 1154 Posted February 28, 2014 Posted February 28, 2014 You get two? I only get one per movie. Would like to be able to download more automatically.
Koleckai Silvestri 1154 Posted February 28, 2014 Posted February 28, 2014 did you check the setting to make sure its set to higher? Mine is currently set to 3 and it downloads 1. Run the same content through MCM and it downloads up to 10.
Teddy 100 Posted February 28, 2014 Author Posted February 28, 2014 Yes, even with a scratch installation and choosing 6 backdrops. If you read some posts there are people with same issue.
Solution Luke 42290 Posted February 28, 2014 Solution Posted February 28, 2014 it should download more now, however, it's not going to fo and re-download them for existing titles. new titles going forward should do much better. for existing titles you can use the refresh feature in the editor. 1
Teddy 100 Posted February 28, 2014 Author Posted February 28, 2014 Then it would be advisable to uninstall the server, reinstall it and configure again everything. I can not imagine to use the refresh feature in the editor, editing 4000 movies one by one.
Luke 42290 Posted February 28, 2014 Posted February 28, 2014 yea once we scan an item once, it's hands off from there on out. Another option is enable the automatic update feature. Then you'll see new images added automatically, over a period of time.
Teddy 100 Posted February 28, 2014 Author Posted February 28, 2014 Luke, the backdrop issue is fixed now. But it has been necessary to do a new installation and configure everything.I will now generate the backdrops that are not in TMDB again...hard work (as you know the rules of TMDB does not create a new movie if they consider it a show or something)
