ryzilla 13 Posted September 20, 2017 Posted September 20, 2017 (edited) Hi guys, I have a nuc running ET and ES combo and getting some weird ass display issues. when emby loads it opens full screen ok but when you play anything its all boxed and you need to minimize then maximize then it runs fine. I have the same setup at home and i dont have any issues, both setup the same but the only diff is this TV having the issue is 4k. any ideas on what could be causing this? Edited September 20, 2017 by ryzilla
ryzilla 13 Posted September 20, 2017 Author Posted September 20, 2017 (edited) i3-7100U 2.40GHz, thanks for asking. Edited September 20, 2017 by ryzilla
ryzilla 13 Posted September 20, 2017 Author Posted September 20, 2017 i cant check atm but i think it was 125% as running native i need binoculars
ryzilla 13 Posted December 9, 2017 Author Posted December 9, 2017 Got the same issue now on my 60" plasma
Luke 42243 Posted December 9, 2017 Posted December 9, 2017 have you made sure windows updates are fully up to date? you may also want to uninstall the app then reinstall, this way you can try again at default settings. thanks !
Getumzz 13 Posted December 9, 2017 Posted December 9, 2017 I'm having the same issue. If I minimize ET and maximize it it scale to the right size. It like the upscale from 720p to 1080p doesnt really work. My GPU is a AMD RX 560. I have reinstalled ET with default settings.
