Guest Arg Posted September 18, 2017 Posted September 18, 2017 (edited) Hi, While using Firefox, IE or Safari I can't stream any .mkv file. However it works with Chrome (you have to wait 10-20 seconds before the movie starts) While using Firefox, IE, Safari or Chrome : all the .avi files look terrible (very blurry, quality very inferior to 420p). However, all these .avi or .mkv work fine when I stream them using VLC or SMPlayer. On the other hand all the .mp4 can be streamed from the web player without any issue no matter what browser I use. I can convert batch .mkv and .avi to .mp4 (this format is always fine) using ffmeg but it's an hit and miss with some movies. EDIT : It seems some .avi that are currently playing with a very bad quality were being streamed perfectly fine a week ago or more. Edited September 18, 2017 by Arg
Luke 42242 Posted September 18, 2017 Posted September 18, 2017 @@Arg, these are fully compatible with the web app. If you're having an issue, please attach the information requested in how to report a media playback issue. thanks !
Guest Arg Posted September 18, 2017 Posted September 18, 2017 (edited) Ok here is the log of the transcoding (.avi) Application version: 3.2.30.0 https://myserver.net:8920/emby/videos/349b7f6b67c47a6920eb927ef2aa03cx/hls1/main/576.ts?DeviceId=e00719a19ecaef693feeb8e2e5509a7ca727dc97&MediaSourceId=349b7f6b67c47a6920eb927ef2aa03c7&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3888000&AudioBitrate=112000&Level=51&Profile=high&PlaySessionId=d387c2bbc45349238ae707631b2f3c15&api_key=dd885e0215a4498e93885e09eb0438ce&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=15fdccb1dd01bae0598a3fd1b52664d7&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&TranscodeReasons=ContainerNotSupported,VideoCodecNotSupported,AudioCodecNotSupported {"Protocol":"File","Id":"349b7f6b67c47a6920eb927ef2aa03cx","Path":"/home/emby/Brain Damage.avi","Type":"Default","Container":"avi","Name":"SD/MPEG4/MP3","IsRemote":false,"ETag":"15fdccb1dd01bae0598a3fd1b52664d7","RunTimeTicks":52859940000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"EnableMpDecimate":false,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"mpeg4","CodecTag":"XVID","TimeBase":"125/2997","CodecTimeBase":"911/21845","IsInterlaced":false,"BitRate":994072,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":360,"Width":640,"AverageFrameRate":23.976,"RealFrameRate":23.976,"Profile":"Advanced Simple Profile","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":5,"IsAnamorphic":false},{"Codec":"mp3","TimeBase":"1/14000","CodecTimeBase":"1/44100","DisplayTitle":"MP3 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":112000,"Channels":2,"SampleRate":44100,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"srt","Language":"eng","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/home/emby/Brain Damage.eng.srt","IsAnamorphic":true},{"Codec":"srt","Language":"fre","DisplayTitle":"Fre","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":3,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/home/emby/Brain Damage.fre.srt","IsAnamorphic":true},{"Codec":"srt","Language":"spa","DisplayTitle":"Spa","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":4,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/home/emby/Brain Damage.spa.srt","IsAnamorphic":true}],"Formats":[],"Bitrate":1115436,"RequiredHttpHeaders":{}} User policy for Arg: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True ffmpeg -ss 00:28:48.000 -f avi -i file:"/home/emby/Brain Damage.avi" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 1988144 -bufsize 3976288 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,1280)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 2 -ab 112000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -segment_time_delta -1728 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 576 -segment_list "/var/lib/emby-server/transcoding-temp/70de736822e88fe2fd33a46c4dfd7642.m3u8" -y "/var/lib/emby-server/transcoding-temp/70de736822e88fe2fd33a46c4dfd7642%d.ts" ffmpeg version 2.6.8 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4) configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-gnutls --enable-ladspa --enable-libass --enable-libcdio --enable-libdc1394 --enable-libfaac --enable-nonfree --enable-libfdk-aac --enable-nonfree --disable-indev=jack --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-openal --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libx264 --enable-libx265 --enable-libxvid --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect libavutil 54. 20.100 / 54. 20.100 libavcodec 56. 26.100 / 56. 26.100 libavformat 56. 25.101 / 56. 25.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 11.102 / 5. 11.102 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 [mpeg4 @ 0x1b85980] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using a tool like VirtualDub or avidemux to fix it. Input #0, avi, from 'file:/home/emby/Brain Damage.avi': Metadata: encoder : VirtualDubMod 1.5.4.1 (build 2066/release) Duration: 01:28:05.99, start: 0.000000, bitrate: 1115 kb/s Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 994 kb/s, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16p, 112 kb/s [libx264 @ 0x1b93ca0] using SAR=1/1 [libx264 @ 0x1b93ca0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0x1b93ca0] profile Main, level 4.1 [libx264 @ 0x1b93ca0] 264 - core 142 r2495 6a301b6 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=1988 vbv_bufsize=3976 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 Output #0, segment, to '/var/lib/emby-server/transcoding-temp/70de736822e88fe2fd33a46c4dfd7642%d.ts': Metadata: encoder : Lavf56.25.101 Stream #0:0: Video: h264 (libx264), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=-1--1, max. 1988 kb/s, 23.98 fps, 90k tbn, 23.98 tbc Metadata: encoder : Lavc56.26.100 libx264 Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp, 112 kb/s Metadata: encoder : Lavc56.26.100 aac Stream mapping: Stream #0:0 -> #0:0 (mpeg4 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (mp3 (native) -> aac (native)) Press [q] to stop, [?] for help [mp3 @ 0x1b8a0e0] Header missing Error while decoding stream #0:1: Invalid data found when processing input [mp3 @ 0x1b8a0e0] Header missing Error while decoding stream #0:1: Invalid data found when processing input [mp3 @ 0x1b8a0e0] Header missing Error while decoding stream #0:1: Invalid data found when processing input [mpeg4 @ 0x20ac340] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using a tool like VirtualDub or avidemux to fix it. frame= 73 fps=0.0 q=28.0 size=N/A time=00:28:51.64 bitrate=N/A frame= 201 fps=201 q=28.0 size=N/A time=00:28:56.98 bitrate=N/A frame= 331 fps=220 q=32.0 size=N/A time=00:29:02.41 bitrate=N/A frame= 461 fps=230 q=32.0 size=N/A time=00:29:07.85 bitrate=N/A frame= 602 fps=241 q=28.0 size=N/A time=00:29:13.68 bitrate=N/A frame= 731 fps=243 q=28.0 size=N/A time=00:29:19.04 bitrate=N/A frame= 849 fps=242 q=28.0 size=N/A time=00:29:24.01 bitrate=N/A frame= 986 fps=246 q=28.0 size=N/A time=00:29:29.70 bitrate=N/A frame= 1107 fps=245 q=28.0 size=N/A time=00:29:34.78 bitrate=N/A frame= 1213 fps=242 q=28.0 size=N/A time=00:29:39.19 bitrate=N/A frame= 1316 fps=238 q=28.0 size=N/A time=00:29:43.47 bitrate=N/A frame= 1415 fps=235 q=28.0 size=N/A time=00:29:47.60 bitrate=N/A frame= 1536 fps=235 q=28.0 size=N/A time=00:29:52.66 bitrate=N/A frame= 1675 fps=238 q=28.0 size=N/A time=00:29:58.44 bitrate=N/A frame= 1805 fps=240 q=28.0 size=N/A time=00:30:03.88 bitrate=N/A frame= 1936 fps=241 q=28.0 size=N/A time=00:30:09.36 bitrate=N/A frame= 2058 fps=241 q=28.0 size=N/A time=00:30:14.44 bitrate=N/A frame= 2186 fps=242 q=28.0 size=N/A time=00:30:19.76 bitrate=N/A frame= 2315 fps=243 q=28.0 size=N/A time=00:30:25.10 bitrate=N/A frame= 2459 fps=245 q=28.0 size=N/A time=00:30:31.14 bitrate=N/A frame= 2603 fps=247 q=28.0 size=N/A time=00:30:37.15 bitrate=N/A frame= 2767 fps=250 q=28.0 size=N/A time=00:30:44.03 bitrate=N/A frame= 2947 fps=255 q=28.0 size=N/A time=00:30:51.50 bitrate=N/A frame= 3106 fps=258 q=28.0 size=N/A time=00:30:58.12 bitrate=N/A frame= 3257 fps=259 q=28.0 size=N/A time=00:31:04.46 bitrate=N/A frame= 3438 fps=263 q=28.0 size=N/A time=00:31:12.01 bitrate=N/A frame= 3612 fps=266 q=25.0 size=N/A time=00:31:19.20 bitrate=N/A frame= 3782 fps=269 q=28.0 size=N/A time=00:31:26.33 bitrate=N/A frame= 3955 fps=272 q=28.0 size=N/A time=00:31:33.55 bitrate=N/A frame= 4118 fps=273 q=28.0 size=N/A time=00:31:40.38 bitrate=N/A frame= 4272 fps=275 q=28.0 size=N/A time=00:31:46.77 bitrate=N/A frame= 4438 fps=276 q=28.0 size=N/A time=00:31:53.68 bitrate=N/A frame= 4624 fps=279 q=28.0 size=N/A time=00:32:01.44 bitrate=N/A frame= 4786 fps=280 q=28.0 size=N/A time=00:32:08.20 bitrate=N/A frame= 4953 fps=282 q=28.0 size=N/A time=00:32:15.16 bitrate=N/A frame= 5095 fps=282 q=28.0 size=N/A time=00:32:21.08 bitrate=N/A frame= 5217 fps=281 q=28.0 size=N/A time=00:32:26.17 bitrate=N/A frame= 5344 fps=280 q=28.0 size=N/A time=00:32:31.46 bitrate=N/A frame= 5456 fps=278 q=28.0 size=N/A time=00:32:36.18 bitrate=N/A frame= 5579 fps=278 q=28.0 size=N/A time=00:32:41.29 bitrate=N/A frame= 5710 fps=277 q=28.0 size=N/A time=00:32:46.77 bitrate=N/A frame= 5834 fps=277 q=28.0 size=N/A time=00:32:51.92 bitrate=N/A frame= 5958 fps=276 q=28.0 size=N/A time=00:32:57.08 bitrate=N/A frame= 6078 fps=275 q=28.0 size=N/A time=00:33:02.11 bitrate=N/A frame= 6208 fps=275 q=28.0 size=N/A time=00:33:07.52 bitrate=N/A frame= 6335 fps=274 q=28.0 size=N/A time=00:33:12.80 bitrate=N/A frame= 6454 fps=273 q=28.0 size=N/A time=00:33:17.79 bitrate=N/A frame= 6577 fps=273 q=28.0 size=N/A time=00:33:22.92 bitrate=N/A frame= 6691 fps=272 q=28.0 size=N/A time=00:33:27.66 bitrate=N/A frame= 6816 fps=271 q=28.0 size=N/A time=00:33:32.88 bitrate=N/A frame= 6934 fps=271 q=28.0 size=N/A time=00:33:37.78 bitrate=N/A frame= 7055 fps=270 q=28.0 size=N/A time=00:33:42.84 bitrate=N/A frame= 7175 fps=269 q=28.0 size=N/A time=00:33:47.86 bitrate=N/A frame= 7300 fps=269 q=28.0 size=N/A time=00:33:53.04 bitrate=N/A frame= 7422 fps=269 q=28.0 size=N/A time=00:33:58.17 bitrate=N/A frame= 7538 fps=268 q=28.0 size=N/A time=00:34:03.00 bitrate=N/A frame= 7659 fps=267 q=28.0 size=N/A time=00:34:08.04 bitrate=N/A frame= 7784 fps=267 q=25.0 size=N/A time=00:34:13.26 bitrate=N/A frame= 7908 fps=267 q=28.0 size=N/A time=00:34:18.44 bitrate=N/A frame= 8025 fps=266 q=28.0 size=N/A time=00:34:23.29 bitrate=N/A frame= 8138 fps=266 q=28.0 size=N/A time=00:34:28.00 bitrate=N/A frame= 8258 fps=265 q=28.0 size=N/A time=00:34:33.02 bitrate=N/A frame= 8370 fps=264 q=28.0 size=N/A time=00:34:37.69 bitrate=N/A frame= 8499 fps=264 q=28.0 size=N/A time=00:34:43.07 bitrate=N/A frame= 8633 fps=264 q=28.0 size=N/A time=00:34:48.67 bitrate=N/A frame= 8760 fps=264 q=28.0 size=N/A time=00:34:53.96 bitrate=N/A frame= 8864 fps=263 q=28.0 size=N/A time=00:34:58.28 bitrate=N/A frame= 9005 fps=264 q=28.0 size=N/A time=00:35:04.18 bitrate=N/A frame= 9132 fps=263 q=28.0 size=N/A time=00:35:09.48 bitrate=N/A frame= 9259 fps=263 q=28.0 size=N/A time=00:35:14.75 bitrate=N/A frame= 9411 fps=264 q=28.0 size=N/A time=00:35:21.13 bitrate=N/A frame= 9572 fps=265 q=28.0 size=N/A time=00:35:27.82 bitrate=N/A frame= 9708 fps=265 q=28.0 size=N/A time=00:35:33.49 bitrate=N/A frame= 9833 fps=265 q=28.0 size=N/A time=00:35:38.71 bitrate=N/A frame= 9975 fps=265 q=28.0 size=N/A time=00:35:44.61 bitrate=N/A frame=10098 fps=265 q=28.0 size=N/A time=00:35:49.76 bitrate=N/A frame=10223 fps=264 q=28.0 size=N/A time=00:35:54.99 bitrate=N/A frame=10375 fps=265 q=28.0 size=N/A time=00:36:01.28 bitrate=N/A frame=10534 fps=265 q=28.0 size=N/A time=00:36:07.94 bitrate=N/A frame=10682 fps=266 q=28.0 size=N/A time=00:36:14.14 bitrate=N/A frame=10841 fps=266 q=28.0 size=N/A time=00:36:20.74 bitrate=N/A frame=10849 fps=266 q=-1.0 Lsize=N/A time=00:36:21.11 bitrate=N/A video:37335kB audio:6212kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0x1b93ca0] frame I:755 Avg QP:26.77 size: 11789 [libx264 @ 0x1b93ca0] frame P:4085 Avg QP:22.53 size: 5493 [libx264 @ 0x1b93ca0] frame B:6009 Avg QP:25.51 size: 1147 [libx264 @ 0x1b93ca0] consecutive B-frames: 16.6% 25.6% 9.5% 48.3% [libx264 @ 0x1b93ca0] mb I I16..4: 33.4% 0.0% 66.6% [libx264 @ 0x1b93ca0] mb P I16..4: 20.1% 0.0% 0.0% P16..4: 55.8% 0.0% 0.0% 0.0% 0.0% skip:24.1% [libx264 @ 0x1b93ca0] mb B I16..4: 1.4% 0.0% 0.0% B16..8: 22.4% 0.0% 0.0% direct: 5.5% skip:70.6% L0:31.0% L1:47.7% BI:21.3% [libx264 @ 0x1b93ca0] coded y,uvDC,uvAC intra: 52.6% 52.8% 16.0% inter: 14.4% 12.5% 0.7% [libx264 @ 0x1b93ca0] i16 v,h,dc,p: 40% 24% 24% 13% [libx264 @ 0x1b93ca0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 18% 17% 9% 7% 6% 6% 5% 5% [libx264 @ 0x1b93ca0] i8c dc,h,v,p: 41% 22% 27% 9% [libx264 @ 0x1b93ca0] Weighted P-Frames: Y:1.8% UV:0.6% [libx264 @ 0x1b93ca0] kb/s:675.90 Edited September 18, 2017 by Arg
Luke 42242 Posted September 18, 2017 Posted September 18, 2017 Ok, for the next release we'll try allowing for a higher bitrate here and that should improve quality. Any other examples? Thanks.
Guest Arg Posted September 18, 2017 Posted September 18, 2017 (edited) Application version: 3.2.30.0 https://myserver.net:8920/emby/videos/08dde93453c022fb7cc4cf0a5edded9x/hls1/main/737.ts?DeviceId=8de73ed972defed82e375c7d6cf682f31b168bc4&MediaSourceId=08dde93453c022fb7cc4cf0a5edded94&VideoCodec=h264&AudioCodec=aac&AudioStreamIndex=1&VideoBitrate=3779956&AudioBitrate=384000&Level=51&Profile=high&PlaySessionId=64a73baa0d0d4d7ca01170f82c1a4f55&api_key=5fa7bb72b6574fb180a5f8993b7825b2&CopyTimestamps=false&TranscodingMaxAudioChannels=6&EnableSubtitlesInManifest=false&Tag=5759da2386251f7f700fe284068b8950&RequireAvc=true&RequireNonAnamorphic=false&DeInterlace=true&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&TranscodeReasons=AudioCodecNotSupported {"Protocol":"File","Id":"08dde93453c022fb7cc4cf0a5edded9x","Path":"/home/emby/Metropolis/Metropolis.mp4","Type":"Default","Container":"mov,mp4,m4a,3gp,3g2,mj2","Name":"720P/H264/AC3","IsRemote":false,"ETag":"5759da2386251f7f700fe284068b8950","RunTimeTicks":91796152320,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"SupportsProbing":true,"EnableMpDecimate":false,"RequiresLooping":false,"VideoType":"VideoFile","MediaStreams":[{"Codec":"h264","CodecTag":"avc1","Language":"und","TimeBase":"1/96000","CodecTimeBase":"1001/48000","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":464919,"BitDepth":8,"RefFrames":6,"IsDefault":true,"IsForced":false,"Height":544,"Width":1280,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"High 10","Type":"Video","AspectRatio":"2.35:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p10le","Level":40,"IsAnamorphic":false},{"Codec":"ac3","CodecTag":"ac-3","Language":"und","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"Und Dolby Digital 5.1 Default","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":384000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0,"IsAnamorphic":false},{"Codec":"srt","Language":"eng","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/home/emby/Metropolis/Metropolis.eng.srt","IsAnamorphic":true}],"Formats":[],"Bitrate":851474,"RequiredHttpHeaders":{}} User policy for Arg: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True ffmpeg -ss 00:36:51.000 -f mov,mp4,m4a,3gp,3g2,mj2 -i file:"/home/emby/Metropolis/Metropolis.mp4" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx264 -pix_fmt yuv420p -preset veryfast -crf 23 -maxrate 929838 -bufsize 1859676 -profile:v high -level 4.1 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "scale=trunc(min(max(iw\,ih*dar)\,720)/2)*2:trunc(ow/dar/2)*2" -copyts -vsync -1 -codec:a:0 aac -strict experimental -ac 6 -ab 384000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -segment_time_delta -2211 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 737 -segment_list "/var/lib/emby-server/transcoding-temp/09e18108720de1d37b827fd2cf0b489c.m3u8" -y "/var/lib/emby-server/transcoding-temp/09e18108720de1d37b827fd2cf0b489c%d.ts" ffmpeg version 2.6.8 Copyright (c) 2000-2016 the FFmpeg developers built with gcc 4.8.5 (GCC) 20150623 (Red Hat 4.8.5-4) configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-gnutls --enable-ladspa --enable-libass --enable-libcdio --enable-libdc1394 --enable-libfaac --enable-nonfree --enable-libfdk-aac --enable-nonfree --disable-indev=jack --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-openal --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libx264 --enable-libx265 --enable-libxvid --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect libavutil 54. 20.100 / 54. 20.100 libavcodec 56. 26.100 / 56. 26.100 libavformat 56. 25.101 / 56. 25.101 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 11.102 / 5. 11.102 libavresample 2. 1. 0 / 2. 1. 0 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:/home/emby/Metropolis/Metropolis.mp4': Metadata: major_brand : isom minor_version : 1 compatible_brands: isomavc1 creation_time : 2012-05-18 07:24:18 Duration: 02:32:59.62, start: 0.000000, bitrate: 851 kb/s Stream #0:0(und): Video: h264 (High 10) (avc1 / 0x31637661), yuv420p10le, 1280x544 [SAR 1:1 DAR 40:17], 464 kb/s, 23.98 fps, 23.98 tbr, 96k tbn, 47.95 tbc (default) Metadata: creation_time : 2012-05-18 07:24:18 Stream #0:1(und): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 384 kb/s (default) Metadata: creation_time : 2012-05-18 07:24:34 Side data: unknown side data type 7 (4 bytes) [libx264 @ 0x17c5c20] using SAR=1/1 [libx264 @ 0x17c5c20] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX [libx264 @ 0x17c5c20] profile Main, level 4.1 [libx264 @ 0x17c5c20] 264 - core 142 r2495 6a301b6 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=929 vbv_bufsize=1859 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 Output #0, segment, to '/var/lib/emby-server/transcoding-temp/09e18108720de1d37b827fd2cf0b489c%d.ts': Metadata: encoder : Lavf56.25.101 Stream #0:0: Video: h264 (libx264), yuv420p, 720x306 [SAR 1:1 DAR 40:17], q=-1--1, max. 929 kb/s, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc56.26.100 libx264 Stream #0:1: Audio: aac, 48000 Hz, 5.1, fltp, 384 kb/s (default) Metadata: encoder : Lavc56.26.100 aac Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264)) Stream #0:1 -> #0:1 (ac3 (native) -> aac (native)) Press [q] to stop, [?] for help frame= 36 fps=0.0 q=36.0 size=N/A time=00:36:52.77 bitrate=N/A frame= 138 fps=137 q=37.0 size=N/A time=00:36:56.99 bitrate=N/A frame= 239 fps=159 q=38.0 size=N/A time=00:37:01.51 bitrate=N/A frame= 347 fps=173 q=38.0 size=N/A time=00:37:05.67 bitrate=N/A frame= 446 fps=178 q=36.0 size=N/A time=00:37:09.92 bitrate=N/A frame= 545 fps=181 q=35.0 size=N/A time=00:37:13.99 bitrate=N/A frame= 648 fps=184 q=35.0 size=N/A time=00:37:18.47 bitrate=N/A frame= 742 fps=182 q=35.0 size=N/A time=00:37:22.14 bitrate=N/A frame= 844 fps=184 q=28.0 size=N/A time=00:37:26.73 bitrate=N/A frame= 941 fps=185 q=28.0 size=N/A time=00:37:30.46 bitrate=N/A frame= 1039 fps=186 q=28.0 size=N/A time=00:37:34.54 bitrate=N/A frame= 1138 fps=187 q=28.0 size=N/A time=00:37:38.65 bitrate=N/A frame= 1237 fps=188 q=28.0 size=N/A time=00:37:42.79 bitrate=N/A frame= 1326 fps=187 q=28.0 size=N/A time=00:37:46.91 bitrate=N/A frame= 1422 fps=187 q=29.0 size=N/A time=00:37:50.60 bitrate=N/A frame= 1516 fps=187 q=33.0 size=N/A time=00:37:54.72 bitrate=N/A frame= 1619 fps=188 q=28.0 size=N/A time=00:37:58.86 bitrate=N/A frame= 1737 fps=191 q=28.0 size=N/A time=00:38:03.91 bitrate=N/A frame= 1854 fps=193 q=28.0 size=N/A time=00:38:08.67 bitrate=N/A frame= 1967 fps=195 q=28.0 size=N/A time=00:38:13.53 bitrate=N/A frame= 2074 fps=196 q=28.0 size=N/A time=00:38:17.74 bitrate=N/A frame= 2172 fps=196 q=28.0 size=N/A time=00:38:21.79 bitrate=N/A frame= 2261 fps=195 q=28.0 size=N/A time=00:38:25.74 bitrate=N/A frame= 2349 fps=194 q=28.0 size=N/A time=00:38:29.21 bitrate=N/A frame= 2437 fps=193 q=28.0 size=N/A time=00:38:32.86 bitrate=N/A frame= 2525 fps=193 q=28.0 size=N/A time=00:38:36.94 bitrate=N/A frame= 2620 fps=193 q=28.0 size=N/A time=00:38:40.61 bitrate=N/A frame= 2716 fps=193 q=28.0 size=N/A time=00:38:44.74 bitrate=N/A frame= 2822 fps=193 q=25.0 size=N/A time=00:38:49.10 bitrate=N/A frame= 2932 fps=194 q=28.0 size=N/A time=00:38:53.58 bitrate=N/A frame= 3042 fps=195 q=28.0 size=N/A time=00:38:58.33 bitrate=N/A frame= 3141 fps=195 q=28.0 size=N/A time=00:39:02.15 bitrate=N/A frame= 3240 fps=195 q=28.0 size=N/A time=00:39:06.72 bitrate=N/A frame= 3350 fps=196 q=28.0 size=N/A time=00:39:10.98 bitrate=N/A frame= 3460 fps=196 q=28.0 size=N/A time=00:39:15.78 bitrate=N/A frame= 3570 fps=197 q=28.0 size=N/A time=00:39:20.48 bitrate=N/A frame= 3680 fps=198 q=28.0 size=N/A time=00:39:24.83 bitrate=N/A frame= 3790 fps=198 q=28.0 size=N/A time=00:39:29.63 bitrate=N/A frame= 3900 fps=199 q=28.0 size=N/A time=00:39:34.05 bitrate=N/A frame= 4010 fps=199 q=28.0 size=N/A time=00:39:38.50 bitrate=N/A frame= 4120 fps=200 q=28.0 size=N/A time=00:39:43.39 bitrate=N/A frame= 4234 fps=200 q=28.0 size=N/A time=00:39:48.04 bitrate=N/A frame= 4347 fps=201 q=28.0 size=N/A time=00:39:52.61 bitrate=N/A frame= 4460 fps=202 q=28.0 size=N/A time=00:39:57.21 bitrate=N/A frame= 4571 fps=202 q=28.0 size=N/A time=00:40:01.82 bitrate=N/A frame= 4681 fps=202 q=28.0 size=N/A time=00:40:06.47 bitrate=N/A frame= 4791 fps=203 q=28.0 size=N/A time=00:40:11.02 bitrate=N/A frame= 4901 fps=203 q=28.0 size=N/A time=00:40:15.71 bitrate=N/A frame= 5000 fps=203 q=28.0 size=N/A time=00:40:20.13 bitrate=N/A frame= 5099 fps=203 q=28.0 size=N/A time=00:40:24.16 bitrate=N/A frame= 5209 fps=203 q=28.0 size=N/A time=00:40:28.57 bitrate=N/A frame= 5319 fps=204 q=28.0 size=N/A time=00:40:33.18 bitrate=N/A frame= 5427 fps=204 q=28.0 size=N/A time=00:40:37.60 bitrate=N/A frame= 5528 fps=204 q=28.0 size=N/A time=00:40:42.01 bitrate=N/A frame= 5638 fps=204 q=28.0 size=N/A time=00:40:46.49 bitrate=N/A frame= 5737 fps=204 q=28.0 size=N/A time=00:40:50.78 bitrate=N/A frame= 5847 fps=204 q=28.0 size=N/A time=00:40:55.05 bitrate=N/A frame= 5953 fps=204 q=28.0 size=N/A time=00:40:59.61 bitrate=N/A frame= 6061 fps=204 q=28.0 size=N/A time=00:41:04.20 bitrate=N/A frame= 6146 fps=204 q=28.0 size=N/A time=00:41:07.87 bitrate=N/A frame= 6254 fps=204 q=28.0 size=N/A time=00:41:12.29 bitrate=N/A frame= 6364 fps=204 q=28.0 size=N/A time=00:41:16.64 bitrate=N/A frame= 6471 fps=204 q=28.0 size=N/A time=00:41:21.18 bitrate=N/A frame= 6573 fps=204 q=28.0 size=N/A time=00:41:25.60 bitrate=N/A frame= 6683 fps=205 q=28.0 size=N/A time=00:41:30.08 bitrate=N/A frame= 6793 fps=205 q=28.0 size=N/A time=00:41:34.49 bitrate=N/A frame= 6892 fps=205 q=28.0 size=N/A time=00:41:39.04 bitrate=N/A frame= 7003 fps=205 q=28.0 size=N/A time=00:41:43.65 bitrate=N/A frame= 7117 fps=205 q=28.0 size=N/A time=00:41:48.23 bitrate=N/A frame= 7222 fps=205 q=28.0 size=N/A time=00:41:52.84 bitrate=N/A frame= 7332 fps=206 q=28.0 size=N/A time=00:41:57.15 bitrate=N/A frame= 7442 fps=206 q=28.0 size=N/A time=00:42:01.61 bitrate=N/A frame= 7552 fps=206 q=28.0 size=N/A time=00:42:06.15 bitrate=N/A frame= 7659 fps=206 q=28.0 size=N/A time=00:42:10.72 bitrate=N/A frame= 7759 fps=206 q=28.0 size=N/A time=00:42:14.86 bitrate=N/A frame= 7853 fps=206 q=28.0 size=N/A time=00:42:18.97 bitrate=N/A frame= 7959 fps=206 q=28.0 size=N/A time=00:42:23.11 bitrate=N/A frame= 8064 fps=206 q=28.0 size=N/A time=00:42:27.68 bitrate=N/A frame= 8168 fps=206 q=28.0 size=N/A time=00:42:31.90 bitrate=N/A frame= 8278 fps=206 q=28.0 size=N/A time=00:42:36.42 bitrate=N/A frame= 8377 fps=206 q=28.0 size=N/A time=00:42:40.93 bitrate=N/A frame= 8485 fps=206 q=28.0 size=N/A time=00:42:45.13 bitrate=N/A frame= 8586 fps=206 q=28.0 size=N/A time=00:42:49.50 bitrate=N/A frame= 8696 fps=206 q=28.0 size=N/A time=00:42:53.90 bitrate=N/A frame= 8795 fps=206 q=28.0 size=N/A time=00:42:58.21 bitrate=N/A frame= 8897 fps=206 q=28.0 size=N/A time=00:43:02.56 bitrate=N/A frame= 8997 fps=206 q=28.0 size=N/A time=00:43:06.70 bitrate=N/A frame= 9092 fps=206 q=28.0 size=N/A time=00:43:10.37 bitrate=N/A frame= 9191 fps=206 q=28.0 size=N/A time=00:43:14.82 bitrate=N/A frame= 9300 fps=206 q=28.0 size=N/A time=00:43:19.07 bitrate=N/A frame= 9400 fps=206 q=28.0 size=N/A time=00:43:23.53 bitrate=N/A frame= 9499 fps=206 q=30.0 size=N/A time=00:43:27.37 bitrate=N/A frame= 9598 fps=206 q=28.0 size=N/A time=00:43:31.53 bitrate=N/A frame= 9697 fps=206 q=28.0 size=N/A time=00:43:35.58 bitrate=N/A frame= 9799 fps=206 q=25.0 size=N/A time=00:43:40.19 bitrate=N/A frame= 9906 fps=206 q=28.0 size=N/A time=00:43:44.33 bitrate=N/A frame=10010 fps=206 q=28.0 size=N/A time=00:43:48.89 bitrate=N/A frame=10111 fps=206 q=28.0 size=N/A time=00:43:53.03 bitrate=N/A frame=10214 fps=206 q=28.0 size=N/A time=00:43:57.15 bitrate=N/A frame=10313 fps=205 q=28.0 size=N/A time=00:44:01.31 bitrate=N/A frame=10410 fps=205 q=28.0 size=N/A time=00:44:05.41 bitrate=N/A frame=10520 fps=206 q=28.0 size=N/A time=00:44:10.01 bitrate=N/A frame=10626 fps=206 q=28.0 size=N/A time=00:44:14.60 bitrate=N/A frame=10732 fps=206 q=28.0 size=N/A time=00:44:19.17 bitrate=N/A frame=10841 fps=206 q=28.0 size=N/A time=00:44:23.33 bitrate=N/A frame=10951 fps=206 q=28.0 size=N/A time=00:44:28.00 bitrate=N/A frame=11061 fps=206 q=28.0 size=N/A time=00:44:32.48 bitrate=N/A frame=11164 fps=206 q=28.0 size=N/A time=00:44:37.09 bitrate=N/A frame=11259 fps=206 q=28.0 size=N/A time=00:44:40.86 bitrate=N/A frame=11358 fps=206 q=28.0 size=N/A time=00:44:45.09 bitrate=N/A frame=11453 fps=206 q=25.0 size=N/A time=00:44:48.99 bitrate=N/A frame=11556 fps=206 q=28.0 size=N/A time=00:44:53.21 bitrate=N/A frame=11673 fps=206 q=28.0 size=N/A time=00:44:58.18 bitrate=N/A frame=11785 fps=206 q=28.0 size=N/A time=00:45:02.75 bitrate=N/A frame=11897 fps=206 q=28.0 size=N/A time=00:45:07.49 bitrate=N/A frame=12006 fps=206 q=28.0 size=N/A time=00:45:11.94 bitrate=N/A frame=12106 fps=206 q=28.0 size=N/A time=00:45:16.51 bitrate=N/A frame=12216 fps=206 q=28.0 size=N/A time=00:45:20.84 bitrate=N/A frame=12326 fps=206 q=28.0 size=N/A time=00:45:25.66 bitrate=N/A frame=12443 fps=207 q=28.0 size=N/A time=00:45:30.31 bitrate=N/A frame=12554 fps=207 q=28.0 size=N/A time=00:45:34.88 bitrate=N/A frame=12663 fps=207 q=28.0 size=N/A time=00:45:39.46 bitrate=N/A frame=12777 fps=207 q=28.0 size=N/A time=00:45:44.29 bitrate=N/A frame=12890 fps=207 q=28.0 size=N/A time=00:45:49.13 bitrate=N/A frame=13001 fps=207 q=28.0 size=N/A time=00:45:53.69 bitrate=N/A frame=13110 fps=207 q=28.0 size=N/A time=00:45:58.28 bitrate=N/A frame=13222 fps=207 q=28.0 size=N/A time=00:46:02.89 bitrate=N/A frame=13330 fps=208 q=28.0 size=N/A time=00:46:07.45 bitrate=N/A frame=13445 fps=208 q=28.0 size=N/A time=00:46:12.04 bitrate=N/A frame=13551 fps=208 q=28.0 size=N/A time=00:46:16.65 bitrate=N/A frame=13657 fps=208 q=28.0 size=N/A time=00:46:21.00 bitrate=N/A frame=13763 fps=208 q=28.0 size=N/A time=00:46:25.35 bitrate=N/A frame=13873 fps=208 q=28.0 size=N/A time=00:46:29.96 bitrate=N/A frame=13976 fps=208 q=28.0 size=N/A time=00:46:34.21 bitrate=N/A frame=14071 fps=208 q=28.0 size=N/A time=00:46:38.22 bitrate=N/A frame=14097 fps=208 q=-1.0 Lsize=N/A time=00:46:39.60 bitrate=N/A video:30894kB audio:26612kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 0x17c5c20] frame I:1009 Avg QP:30.41 size: 10435 [libx264 @ 0x17c5c20] frame P:5491 Avg QP:23.45 size: 3244 [libx264 @ 0x17c5c20] frame B:7597 Avg QP:27.41 size: 434 [libx264 @ 0x17c5c20] consecutive B-frames: 27.1% 1.8% 3.7% 67.4% [libx264 @ 0x17c5c20] mb I I16..4: 60.2% 0.0% 39.8% [libx264 @ 0x17c5c20] mb P I16..4: 2.9% 0.0% 0.0% P16..4: 35.3% 0.0% 0.0% 0.0% 0.0% skip:61.8% [libx264 @ 0x17c5c20] mb B I16..4: 0.2% 0.0% 0.0% B16..8: 6.2% 0.0% 0.0% direct: 2.4% skip:91.1% L0:32.1% L1:42.7% BI:25.1% [libx264 @ 0x17c5c20] coded y,uvDC,uvAC intra: 53.1% 39.1% 17.3% inter: 7.8% 3.7% 0.2% [libx264 @ 0x17c5c20] i16 v,h,dc,p: 39% 24% 24% 14% [libx264 @ 0x17c5c20] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 20% 20% 8% 5% 6% 5% 5% 6% [libx264 @ 0x17c5c20] i8c dc,h,v,p: 58% 18% 20% 5% [libx264 @ 0x17c5c20] Weighted P-Frames: Y:0.9% UV:0.4% [libx264 @ 0x17c5c20] kb/s:430.43 Edited September 18, 2017 by Arg
Luke 42242 Posted September 18, 2017 Posted September 18, 2017 Can you discuss the issue with this example? thanks !
Guest Arg Posted September 19, 2017 Posted September 19, 2017 Can you discuss the issue with this example? thanks ! First example : very bad streaming quality all along Second example : was switching constantly (every 2-3 minutes) from 720p to way beneath 420p
Luke 42242 Posted September 19, 2017 Posted September 19, 2017 What makes you think it was switching?
Guest Arg Posted September 19, 2017 Posted September 19, 2017 (edited) What makes you think it was switching? When I can't even recognize the face of the actors hidden behind a fog of pixels Edited September 19, 2017 by Arg
Guest Arg Posted September 19, 2017 Posted September 19, 2017 (edited) Isn't that a old ffmpeg? Yeah... at first it seemed that the only precompiled ffmpeg version for CentOS was available on the nux-dextop repository (it is referenced everywhere). But I've just checked and it seems it has been compiled in April 2016 ... Ouch ... So I've just found a more recent build for CentOS : wget https://raw.githubusercontent.com/q3aql/ffmpeg-install/master/ffmpeg-install chmod a+x ffmpeg-install ./ffmpeg-install --install release It gives me this version : ffmpeg version 3.3.4-static http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2017 the FFmpeg developers built with gcc 6.4.0 (Debian 6.4.0-4) 20170820 configuration: --enable-gpl --enable-version3 --enable-static --disable-debug --disable-ffplay --disable-indev=sndio --disable-outdev=sndio --cc=gcc-6 --enable-fontconfig --enable-frei0r --enable-gnutls --enable-gray --enable-libfribidi --enable-libass --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-librubberband --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libvorbis --enable-libopus --enable-libtheora --enable-libvidstab --enable-libvo-amrwbenc --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libzimg libavutil 55. 58.100 / 55. 58.100 libavcodec 57. 89.100 / 57. 89.100 libavformat 57. 71.100 / 57. 71.100 libavdevice 57. 6.100 / 57. 6.100 libavfilter 6. 82.100 / 6. 82.100 libswscale 4. 6.100 / 4. 6.100 libswresample 2. 7.100 / 2. 7.100 libpostproc 54. 5.100 / 54. 5.100 I don't don't if I should remove all the former packages from the nux-dextop ... Or maybe only the old ffmpeg ? These packages could be useful for converting videos files ? faac.x86_64 1.28-6.0.el7.nux @nux-dextop fdk-aac.x86_64 0.1.4-1 @nux-dextop ffmpeg.x86_64 2.6.8-3.el7.nux @nux-dextop ffmpeg-devel.x86_64 2.6.8-3.el7.nux @nux-dextop ffmpeg-libs.x86_64 2.6.8-3.el7.nux @nux-dextop libavdevice.x86_64 2.6.8-3.el7.nux @nux-dextop nux-dextop-release.noarch 0-5.el7.nux @nux-dextop x265-libs.x86_64 1.9-1.el7.nux @nux-dextop xvidcore.x86_64 1.3.2-5.el7.nux @nux-dextop Edited September 19, 2017 by Arg
Guest Arg Posted September 19, 2017 Posted September 19, 2017 (edited) This newer ffmpeg doesn't improve the quality of the .avi streaming on my box. Another precision : Since I've experienced issues with the web player, the Ember app has never been affected by the quality drop. So I think it really comes from the web player. Edited September 19, 2017 by Arg
Luke 42242 Posted September 19, 2017 Posted September 19, 2017 Ok, please try again with the next release of emby server, thanks.
