ShoutingMan 101 Posted September 17, 2017 Posted September 17, 2017 Emby Theater 2.8.4 does not seem to use default audio track for at least one TV series. And it is not remembering the audio track selection if I change it, quit the app, and return. I haven't explored further to see if it's just this one show on my server or throughout ET at the moment. In past version (2.8.3 and earlier) the default audio track played as expected. The show is "Dirk Gentlys Holistic Detective Agency". The MKV files have a "Stereo" and a "Dolby Digital 5.1" track. The 5.1 is flagged as Default, using MKVToolNix. But ET plays the stereo track, the first track, everytime. If I manually switch the 5.1 track that plays fine. But quitting and returning, ET reverts back to the stereo track as default. I've attached a log file from when I was playing some shows and experiencing this. Log
Luke 42243 Posted September 17, 2017 Posted September 17, 2017 Tested, no problem found. it is probably remembering from a previous playback session and that is leading you to think that playing the default track is not working.
Guest asrequested Posted September 17, 2017 Posted September 17, 2017 I was running some tests on audio track playing, yesterday (a different but similar issue). When the audio stream is transcoded, no matter how I configured the settings in Theater, when resuming or playing from the beginning, the first audio track would always play. Not the default, but the first track, regardless of what it was.
Luke 42243 Posted September 17, 2017 Posted September 17, 2017 it is probably remembering from a previous playback session and that is leading you to think that playing the default track is not working.
Guest asrequested Posted September 17, 2017 Posted September 17, 2017 it is probably remembering from a previous playback session and that is leading you to think that playing the default track is not working. But if I play something, choose the track, stop playback and then resume, should it not remember that choice? Regardless, if you're correct, then it's remembering that choice in perpetuity. No matter how many times I restarted, it played the first track. Again, this was only when the audio is being transcoded, not when it's direct playing.
ShoutingMan 101 Posted September 22, 2017 Author Posted September 22, 2017 Thamks. It might be related to previous settings. I'd watched some of the episodes streaming to an AppleTV. The audio wasn't in surround, and I found the MKV audio metadata wasn't right. I edited the MKV data to label Stereo and Surround and set the Surround to the default. So it might have be remembering previous settings and/or not updating to revised defaults immediately. Thanks again for checking and the feedkback.
