Baenwort 119 Posted September 17, 2017 Posted September 17, 2017 So, I happen to have an oversized antenna, way to high in the air, and I get stations from outside the region that Schedule Direct thinks I should receive based upon my location. Anyone have any recommendations or guidance on how to populate the Emby LiveTV guide for stations when you're picking up stations from ~120 miles away and stations that are only 12?
Luke 42243 Posted September 17, 2017 Posted September 17, 2017 yes you can setup multiple schedules direct lineups, in order of preference. 1
Baenwort 119 Posted September 24, 2017 Author Posted September 24, 2017 So this would be on the Schedule Direct end? I didn't know that SD served up a single schedule to an account that had all the regions merged.
Luke 42243 Posted September 24, 2017 Posted September 24, 2017 No, what you would do is just add two different schedules direct lineups to emby and assign them both to the same tuner.
