dlehtin 0 Posted September 15, 2017 Posted September 15, 2017 After following the wiki on installing emby, there is only (Indigo) under Video-Add-ons. The only place I can find emby is under System*Setting*Add-ons*My Add-ons*Add-on repository*--Kodi Emby Add-ons (Enabled). I'm running on windows 7, Kodi version 17.4 skin Confluence, Emby version 3.2.30.0. I'm not sure what I'm doing wrong or missing.
Jdiesel 1435 Posted September 15, 2017 Posted September 15, 2017 Sounds like you only installed the repository and not the add-on itself. Go back into the add-ons manager and select install from repository and select the Emby Repository, then videos addons, then Emby.
dlehtin 0 Posted September 15, 2017 Author Posted September 15, 2017 I installed from the zip file (repository.emby.kodi-1.0.3zip) and recieved the pop up message the add-on installed
