Luke 42234 Posted March 9, 2022 Author Posted March 9, 2022 3 hours ago, smartinezpu said: La ultima actualizacion de Emby a traves de aplicaciones no funciona. No elimina las bibliotecas pero es como si no tuviera permisos para leerlas. He tenido que volver a la 4.6 instalandolo de forma manual, y aunque parece funcionar correctamente, el cartel de EMBY PREMIERE aunque estoy suscripto esta permanentemente presente. Es necesario revisar esta versión. Creo que en el post ya se hace referencia al tema pero no se si se ha llegado a alguna solucion. De momento sigo con la 4.6 pero en el servidor web aparece como si no estuviera registrado. En la aplicacion cliente parece que funciona correctamente Gracias de antemano Hi, please try what I suggested here: Thanks.
JVRx7 2 Posted March 9, 2022 Posted March 9, 2022 TerraMaster TOS 5 Global Open Beta Test has been announced, is Emby ready for TOS 5 testing?
Luke 42234 Posted March 9, 2022 Author Posted March 9, 2022 1 hour ago, JVRx7 said: TerraMaster TOS 5 Global Open Beta Test has been announced, is Emby ready for TOS 5 testing? We will certainly look to support their new TOS. Right now we are just trying to help users climb out of the mess that they've created with the updates they've been pushing 1 1
JVRx7 2 Posted March 9, 2022 Posted March 9, 2022 Yes, they've been scrambling to plug holes & educate users on secure configurations as a result of ransomware attacks. I can't help but remember when microsoft turned "everything" on in windoz to cut down on support calls, only to turn almost everything "off" to keep others "out"... I "earned" my gray & white hair.....
charlyp 1 Posted June 19, 2023 Posted June 19, 2023 On 9/14/2017 at 9:36 PM, Luke said: Download & Installation https://emby.media/download Hi, Can I use this "new" method to UPDATE the Emby installation I already have running on my Terramaster since it was installed from the store a few years back? Is there something I need to do first to prevent any data loss? I think I would get mad if the media library was reset or something similar Is the following the right way to do it: stop the Emby server; install the new version downloaded from the Emby website; start the server. Thanks, Ch.
Luke 42234 Posted June 19, 2023 Author Posted June 19, 2023 12 hours ago, charlyp said: Hi, Can I use this "new" method to UPDATE the Emby installation I already have running on my Terramaster since it was installed from the store a few years back? Is there something I need to do first to prevent any data loss? I think I would get mad if the media library was reset or something similar Is the following the right way to do it: stop the Emby server; install the new version downloaded from the Emby website; start the server. Thanks, Ch. Hi, yes you can. Are you on the latest version that the store offers?
charlyp 1 Posted June 20, 2023 Posted June 20, 2023 10 hours ago, Luke said: Hi, yes you can. Are you on the latest version that the store offers? Hey Luke, Thanks for your reply. Yes, I'm on version 4.7.8.0 which is the one available on the store. The previous updates were proposed directly from the Emby server itself, asking to just restart, but now it says "A new version (4.7.13.0) is available. Please shutdown the Emby server and install the latest version". To install the update manually, should I use the 'Install application manually‘ option from the store app then browse to the TPK file? Ch.
Luke 42234 Posted June 27, 2023 Author Posted June 27, 2023 On 6/20/2023 at 4:05 AM, charlyp said: Hey Luke, Thanks for your reply. Yes, I'm on version 4.7.8.0 which is the one available on the store. The previous updates were proposed directly from the Emby server itself, asking to just restart, but now it says "A new version (4.7.13.0) is available. Please shutdown the Emby server and install the latest version". To install the update manually, should I use the 'Install application manually‘ option from the store app then browse to the TPK file? Ch. Hi, yes you can do that to update immediately, or wait for TerraMaster to publish the update. Unfortunately you just never know with them how long they'll take. 1
STR8 74 Posted July 26, 2023 Posted July 26, 2023 Hey Luke, I was wondering if TerraMaster even publish updates anymore because I'm on emby version 4.7.9.0 I know it's been super long since I updated but I never see any update in the TNAS.
Luke 42234 Posted July 26, 2023 Author Posted July 26, 2023 1 hour ago, STR8 said: Hey Luke, I was wondering if TerraMaster even publish updates anymore because I'm on emby version 4.7.9.0 I know it's been super long since I updated but I never see any update in the TNAS. Yea I'll have to find out what the holdup is because have submitted updates to them. They're just not published yet for whatever reason.
STR8 74 Posted September 5, 2023 Posted September 5, 2023 Still no word on this from Terramaster @Luke 1
Luke 42234 Posted September 5, 2023 Author Posted September 5, 2023 30 minutes ago, STR8 said: Still no word on this from Terramaster @Luke We're working on it. I'll let you know more when I know more. Thanks.
STR8 74 Posted February 24, 2024 Posted February 24, 2024 Good Day It's been so long since I had updated my Emby server manually and was wondering if you could give me direction as to where the emby update file should be uploaded in my Terramaster. Thanks in advance.
Luke 42234 Posted February 25, 2024 Author Posted February 25, 2024 On 2/24/2024 at 12:57 PM, STR8 said: Good Day It's been so long since I had updated my Emby server manually and was wondering if you could give me direction as to where the emby update file should be uploaded in my Terramaster. Thanks in advance. Are you on TOS5? There is a function in the Terramaster web interface to manually upload a package file.
STR8 74 Posted February 29, 2024 Posted February 29, 2024 Thanks for the reply I was able to upload 1
STR8 74 Posted January 6, 2025 Posted January 6, 2025 Good day and happy new year to all I was wondering if you could please share the path for the new version upload Emby Server 4.8.10.0 is Available for Home Entertainment should I upload in the root folder? It's been so long, and I don't want to mess up things too much my VirtualTV went out, so I figured I need the new version of Emby for it to work with the new version of the VirtualTV plugin thanks in advance
Luke 42234 Posted January 6, 2025 Author Posted January 6, 2025 8 minutes ago, STR8 said: Good day and happy new year to all I was wondering if you could please share the path for the new version upload Emby Server 4.8.10.0 is Available for Home Entertainment should I upload in the root folder? It's been so long, and I don't want to mess up things too much my VirtualTV went out, so I figured I need the new version of Emby for it to work with the new version of the VirtualTV plugin thanks in advance Hi, TOS has a package install function built into it's web interface now. I would use that.
Luke 42234 Posted January 6, 2025 Author Posted January 6, 2025 15 minutes ago, STR8 said: ok thanks Are you able to find it?
STR8 74 Posted January 6, 2025 Posted January 6, 2025 yes, and i was able to update to the new version thank you 1
Bluntspoon2 0 Posted February 28, 2025 Posted February 28, 2025 (edited) I'm at a loss. F2-223 TOS 5.1 Emby Server will not enable. I have tried 4.8.8.0 through the App store and then 4.8.10.0 and 4.9.0.40 from https://emby.media/terramaster-server.html and then installing through the settings page of the App Center. Really ultra mega super frustrating. Please HALP. Edit - I am able to disable and enable PLEX just fine. Edited February 28, 2025 by Bluntspoon2
Luke 42234 Posted February 28, 2025 Author Posted February 28, 2025 2 hours ago, Bluntspoon2 said: I'm at a loss. F2-223 TOS 5.1 Emby Server will not enable. I have tried 4.8.8.0 through the App store and then 4.8.10.0 and 4.9.0.40 from https://emby.media/terramaster-server.html and then installing through the settings page of the App Center. Really ultra mega super frustrating. Please HALP. Edit - I am able to disable and enable PLEX just fine. Re:
