Emby for TerraMaster NAS
A few times I have not had the app store version installed for about 2 weeks now trying to back door the newest version in
Still getting the unable to connect messages after reboot
zachattack83
But you can get to the tnas admin panel on port 8181 just fine correct?
Yup
zachattack83
can you winspc into your root and send me a screen shot of the /root/ directory?
Yup I renamed the tar.xz to just make it easier to type the commands
zachattack83
Ok, I think i see your problem
When you ssh in as root, before you install the emby, type cd /. Then run the command to extract and then start the service.
zachattack83
cd /
tar -xf ~/emby-server-terramaster_4.2.1.0_x86_64.tar.xz
service emby-server start
cd /
Well this time it took longer to install but still getting the unable to connect message
gonna try to reboot
zachattack83
Does it give you an error message in ssh when you try to start the service?
nope just the next line almost instantly
zachattack83
OK, so its starting up the service.
Can you control f5 on your browser to clear the cache or wahtever that does? gives you a fresh refresh on the page you're trying to load.
no dice I even tried a totally different browser.  IN chrome I am getting connection refused messages
Edited by derrabe
zachattack83
Maybe go back to page one of this forum and run the uninstall commands, and then start from scratch? also, I had originally extracted on the /root/ directory too, and I deleted those files out of there with winspc.
Maybe once you uninstall, and restart, then try a reinstall. maybe some leftovers in there causing some issues.
told me I donthave a group called emby on the last step
zachattack83
that should be fine, thats the last command, just to delete a user group. if its not there, shouldn't be an issue. (shouldn't be)
nope still no dice, I copied the file to the /root directory and ran it again and started the service still unable to connect
zachattack83
I think I am out of ideas! hopefully someone from emby picks up on this and can offer you some advice. Thats about all I have :(
well hmm  I might have been running the start command wrong with a underscore instead of the dash becuase now I am getting a new error when I tried that.
adduser: unknown group emby
chown: unknown user/group emby:emby
start-stop-daemon: group 'emby' not found
am i supposed to be putting the file in root folder or / <root>
Edited by derrabe
zachattack83
Put the file in the /root/ directory, but run the install from the cd /
Ok yup still getting this error when i try to start the service now.
zachattack83
But you got no errors when you installed it?
nope I just tried to manually add the emby group and rerun and now I get this
adduser: no uids left
start-stop-daemon: user 'emby' not found
zachattack83
Thats very weird. I did not have to add any user groups.
Ok, how about we do this.
Uninstall through the command line, then restart.
Install the app from the app store. And see if it works. If so, Uninstall, and then restart.
Run the install again from the command line.
Start service.
Lets see if that works out any of the bugs.
Start service.
is it just me or does installingi via the app store take forever?
zachattack83
it takes forever lol
