wolf359 6 Posted September 13, 2017 Posted September 13, 2017 I am running Emby server and Theater on the same computer. My tv is connected to the computer graphics card via hdmi Is there a way of setting the computer to play through the tv speakers when emby is running because atm I have to change from my computer speakers used for playing games to the tv sound output for playing emby Also running on windows 10
Guest asrequested Posted September 13, 2017 Posted September 13, 2017 (edited) In windows, what do you have set as your default player? Edited September 14, 2017 by Doofus
Solution Guest asrequested Posted September 13, 2017 Solution Posted September 13, 2017 The answer is yes, you can. You can specify the default device in the mpv.conf. You can take a look in this post. https://emby.media/community/index.php?/topic/47889-how-to-choose-audio-output-device/&do=findComment&comment=482439 If you need more help, I can walk you through it, later tonight. 1
Guest asrequested Posted September 13, 2017 Posted September 13, 2017 Luke, I think it would be a good idea to have this as a selection in the UI.
weedos123 3 Posted September 15, 2017 Posted September 15, 2017 So in win 10 would this mean, I could ditch my ageing AV receiver and use my much much better exasound multichannel usb dac for audio? At the moment ET cant see it as it it isnt a waspi device.
Guest asrequested Posted September 15, 2017 Posted September 15, 2017 If it appears in your audio device list, then it can be used.
